Old 06-05-2017, 04:39 PM   #1
tdangle
tdangle's Avatar
AC Question
I'm working on getting my AC up and running. Will be changing over to R134. Since the metal portion of the line from the condenser to the expansion valve is cracked, I removed the line and opened up the back output of the POA valve. I applied 60 PSI of air to the input of the expansion valve and with a gauge hooked up to the low side connector (on the POA) it opens at 27 psi. Should be 29, correct? Am I doing something wrong?
Air is going thru the expansion valve then thru the evaporator and then to the POA valve. I think this is the correct setup.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-05-2017, 05:46 PM   #2
demian5
demian5's Avatar
Re: AC Question
When AC pressures are in the 100s, does 2 psi matter?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-05-2017, 05:58 PM   #3
tdangle
tdangle's Avatar
Re: AC Question
I agree but everything I have researched says R12 POA is adjusted to 29 and R134 requires 27 psi. I know this one has not been converted to R134 (Parents were original owner). Now I'm thinking, Nice already calibrated for what I need.
Terry
Old 06-05-2017, 07:26 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: AC Question
Good luck with your conversion. If you have factory AC it will NOT work anywhere near as good as with r-12. I'm restoring the factory AC on my truck and will be using r-12. I've done this enough times to know better now As soon as it gets into the 90s here your AC won't work with r-134...ask me how I know. I just bought a case of r-12 on CL for $80...that's cheaper than r-134 at autozone
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
