#1101 |
Happy to be here
![]() Join Date: Mar 2000
Re: 85 GMC Sierra "Scarlett"
I thought about that. I have a spare aluminum band for the back of the cab that I considered cutting up. I decided to try to find a similar vinyl instead.
#1102 |
Happy to be here
Despite several things that didn't go well today, I did have success at the fabric store. I considered all my options for making the top of the box look better and decided to seek out a replacement piece. I assumed that the vinyl I bought wouldnt be available since it was close out priced AND the store I bought it from went out of business.
I went by a JoAnns fabric center today and was shocked to find a bolt of the exact same vinyl. I only needed a 6" strip, but I bought a yard to be safe. I like the grain so much, I may do "The 77_Remix" in the same material. So tonight I went straight to the shop and started the stripping process. Theres no doubt a made a good choice when changing glue brands. Thats great unless your trying to remove it. It did come off, but it wasnt easy. I stripped and sanded the top cap and covered it all in one complete piece this time. It looks so much better now. The weather was not going to give me a break. It is so humid that my dye was guaranteed to blush. I decided to give it a color coat anyway. I will wait till its drier and top coat everything once more.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-05-2017 at 09:52 PM. |
#1103 |
Oh boy, what a lesson that vinyl is giving you for sure! But the patient prevail and you definitely have sir, that box looks off the hook and makes me want to toss the tank out of my 72's cab so much but alas the fund train stopped a few stations early this year
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#1104 | |
Happy to be here
#1105 | |
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#1106 |
Excellent words of wisdom absolutely sir!
#1107 |
Happy to be here
Ding, ding, ding. Round three and I am loosing this battle. I just cant get a break from the humidity. I tried using every fan I could find to move the air, but it wasnt enough. The dye is still blushing. I had to call it quits early tonight.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-07-2017 at 07:42 AM. |
#1108 |
Happy to be here
One more time. The air seemed drier this morning. Tried a test in the shop with bad results. Moved to my side draft paint booth. Much better, but still some small spots blushed. 😣
#1109 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#1110 |
Happy to be here
Its very durable IF you prep in properly. You absolutely must clean everything thoroughly with brake cleaner, then use Bulldog brand adhesion promoter. Follow with very thin coats of dye till you get complete coverage.
#1111 |
Happy to be here
I finally got the last bit of blush covered over yesterday. Last night I spent time in the shop installing the Kicker Hideaway 8" Subwoofer in place. I also installed the LED lighting that will light the storage compartments and around the sub. The adhesive on the strip light was weal, so I used double sided tape to hold the strips in place. I'm still not sure if thats enough. I may have to go back and use Weldwood to get a better bond.
Note that the light is NOT as bright as the pics make it look. The red light had overpowered the cameras filters and I couldn't prevent it from having an evil glow in the pics.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-09-2017 at 01:47 PM. |
#1112 |
![]() Join Date: Feb 2011
Looks great....you don't let up at all on the details, do you? The picture of the uncovered LED reminded me of a past Maroon 5 album cover
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1113 | |
Happy to be here
Not really... ![]()
#1114 |
Happy to be here
It's amazing how a couple of small pieces can be so labor intense. I yet to determine exactly how I was going to fill the void between the end of the box and the cab. I has mocked up a scrap piece early on, to get an idea of what it would take.
I determined then that it was going to suck designing and fitting a filler piece . Not one of the edges in that corner are straight. Each one has multiple angles and curves combined. There is just no easy way out. I started with making templates and adjusting the fit. The box must be in place to ensure accuracy yet the box prohibits you to see or feel what your doing. Combine that with the fact that each is is slightly different and design time doubles. In the end, I prevailed. I can tell you there is a large scrap pile of failed attempts, and there were a few episodes of cursing but I have my filler panels. On a side note, if you looks closely you will see that one is thicker than the other. I'm not pointing an fingers, but my centerline and side to side measurements were checked many, many times. Surely GM wouldn't build a truck that's off by .25 from side to side? Nah, it must be me.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-12-2017 at 09:30 AM. |
#1115 |
If that truck was built on Monday or Friday I am willing to bet it is NOT your measurements.
stone sends... 78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201) 06 Dodge Charger Daytona R/T 05 Suzuki GSX-R 1000 Last edited by st1; 06-11-2017 at 08:12 PM. Reason: Spelling |
#1116 | |
#1117 |
Happy to be here
Sunday was a big day in my shop. I got an early start by running for supplies and started the final push for assembly. All of those additional hours spent sanding a fitting gaps were finally starting to pay off.
Chris arrived and started on the last bit of wiring. We had originally planned to utilize a switch for the LED light strip, but I couldn't find a location to mount it that I liked. We opted to expose the infrared sensor and use the remote control instead. All I wanted was the ability to run red ambient lighting. With the remote we could turn on the audio sensor as well. Now Scarlett has the ability to go full disco mode. Not what I was after, but everyone seems to like it so what do I know. We were able to install everything one last time and finally see the completed results. We spent some time tuning and shot a couple of videos while the seat was still out. The vids are located here JLo and BEP. When I get the seat installed, I will get a few more pics. Enjoy these for now.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-12-2017 at 09:52 AM. |
#1118 | |
Happy to be here
Oh yes, the wonderful world of what bolt is it. We encounter that constantly. Fortunately I have a well stocked tool box so we can accommodate what ever they were using that day.
#1119 | |
I see this process in my future! Appreciate the step by step!
#1120 |
Did you ever go back and talk about what you learn from precision about the door seals?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#1121 |
Happy to be here
For an aerosol application its the best. I have sprayed PPG before and it works great to.
#1122 |
Happy to be here
Not yet. I plan to take that task on this weekend.
#1123 |
Ok, glad I didn't miss it
#1124 |
thank you, I went on SEM's website and did further research, looks like they have all kinds of good stuff available! Thanks for the tip!
#1125 |
Happy to be here
This time of year is super busy at work. I will document the process soon.
They have a great selection. Don't forget the Bulldog brand adhesion promoter too.
