![]() Join Date: Jan 2001
Harbor Freight Tubing Notcher
Harbor Freight is always a roll of the dice. I have a 20-ton shop press I've had over 20 years and it works great. But this week I needed to build some racks out of 1 1/4 inch .120 wall steel tube. I went to HF after dutifully reading the reviews, and true to most of them, I had to shim the clamp to get the hole saw centered - that was no big deal. It wasn't quite square at 90 degrees, but again not a big deal. But then, on the third piece of tubing, the top bushing came out and would not stay in. That made the notcher totally useless. I can't recommend this to anyone, just in case you're thinking about it.
Registered Truck Offender
Re: Harbor Freight Tubing Notcher
Yeah H.f used to be cheaper, and low quality stuff, But for the hobbist,, it seemed to last for the 10-12 uses we put it through over a 10 year span. Now,, not a thing they make I can say is worth buying. I'm sure others have had luck with some of their junk. But my luck with them has ALL been bad for quite a few years now.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
![]() ![]() Join Date: May 2015
I got mine from eastwood..decent quality but I also had to shim the clamp out to get the tube centered..
meowMEOWmeowMEOW
IMO there are a list of Do's and Don't with HF stuff. For the most part stuff like clamps, straps, blocks, chains, tarps etc are all fine for the money. Its for "I need it now" stuff, not "I need it every day" stuff.
I always try to keep stuff like an HF set of wrenches, breaker bars, clamps etc...so I can cut and weld them into oddball special use tools. Stuff like benders, presses, jigs, I look at Northern Tool or Eastwood. They have the "prosumer" and "hobbyist" grade stuff IMO. Eastwood has a great setup for auto specific tools, but you do pay a little more than you might from an HF (if the tool exists at both).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jul 2015
Its a free market. So buyer beware, been down that road with them. Pipe expander snapped first time using it.
So now I love their 9 mil gloves on sale with the 20% off coupon. Other than that, Its only on Halloween at Midnight you will find me at Harbor Fright! Sheez I wont even buy their wrenches to cut up. I get 40 year old Craftsmen at the local tool reseller at a buck a peice for that! Ha take that China! |
#6 | |
There's a local trade day here that has a seller that has tons of old wrenchs and sockets..might try a trade day if you have one local to you
![]() Join Date: Jun 2009
Imo harbor freight, northern tool and eastwood are selling the same crap, they just paint it a different color and put their own labels on it. If you truly compare you can tell there is not a difference in quality just one can charge more than the other because their name has been in the automotive industry longer.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
One foot in front of the other
![]() Join Date: Aug 2008
Words from my dad:
"If you are only going to use it once or twice, buy cheap. If you are going to use it more than that, buy quality." |
The best motto i ever learned for Harbor Freight tools, "Harbor Freight makes it, You make it better." With that in mind, i have modified alot of HF equipment and made them work pretty damn good.
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
True, but I had already modified this one to be square in 3 axis; it was the material failure that doomed it. Yes, I could have bored it out and installed bearings, but that was more than I was willing to do for a HF notcher.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Oh ya, not everything is saveable from them.. pick and choose your battles..
