Old 06-14-2017, 11:26 AM   #1
shp4man
shp4man's Avatar
New 6 cyl. radiators, which one?
Has anybody bought either one of these?
https://www.carid.com/replace/radiator-mpn-rad284.html
or
https://www.carid.com/apdi/radiator-...8&url=78219899
The RAD284 one says it's a US made brass radiator, while the ADPI one says it's an aluminum one. Pic doesn't look like an aluminum radiator.
I like these two because they look like the old Harrison, which in my truck is beginning to fall apart. Not enough stop leak in the world to save it.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 06-14-2017, 11:39 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 6 cyl. radiators, which one?
ADPI also says:
"...Row: 1. Construction: Plastic Tank Aluminum..."
Old 06-14-2017, 12:18 PM   #3
shp4man
shp4man's Avatar
Yep, and if you search Amazon for the RAD284 one, it says "Origin USA, multiple manufacturers".
For a few extra bucks, that may be the better choice.
I wonder if they just put the wrong picture in on the other one?
Old 06-14-2017, 03:12 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
If you can, double check with a couple of local radiator shops to see if they have access to and better pricing on the radiator you want/need - just in case they can pass along volume/distributor pricing. On the last couple of projects, I worked with a local (to me) radiator shop that was able to get me a US Radiator part number for a lot less than retail/online pricing. It might be worth it if it saves you a few bucks on a US-made radiator.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-14-2017, 03:41 PM   #5
The Rocknrod
Moderator
He's right. I went to a radiator shop in Covina, CA (I think) and bought a US Radiator for $3 hundred and some odd dollars. It was listed for over $600.
First time that ever happened to me in life.
Old 06-14-2017, 09:25 PM   #6
Ken Cook
Ken Cook's Avatar
Yea, check the local radiator shop. I needed on for a 65 Mustang and he had it on the shelf for $150.
Ken Cook is offline   Reply With Quote
