Coolant overflow tank for 71
Greetings
Anyone know of a coolant overflow tank that will bolt to the passenger side wheel well. I found this one on the Dorman site and it looks like it could possible fit. Dorman Coolant Reservoirs 603-100 https://www.summitracing.com/int/par...make/chevrolet I DID search for this answer but only found one really old thread that didn't have current links. thanks |
![]() Join Date: Feb 2016
Re: Coolant overflow tank for 71
Do a search. Just after I put an S10 tank in my Burban I ran across a thread using a 80's Monte Carlo (I think) overflow that was nice and clean and easy. My WMB thread has photos of the S10 installation. I have also seen a stock repop that goes on the drivers side.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: May 2004
I have on on my 69 Burb.....This was years ago that I did this, but I believe it is from an 80s Monte like was mentioned. It fits real good on the passenger side inner fender.
I'm using a windshield washer bottle and bracket from a 69 Camaro. Works fine.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
Run it out onto the ground like God intended, there are too many stray dogs anyway.
![]() Seriously though, that would be an option for me. I never intend to operate my truck below freezing, distilled water wouldn't hurt anything running out onto the ground. I could drain the radiator when parked for winter like horseless carriage owners used to do. ![]() There is a guy on the forum in the parts section that sells reproduction overflow tanks, you can get one out of a junkyard, get one from Jegs or Summit, or make one. AFTER SOME REFLECTION, MY IDEA ISN'T SO GREAT. What will I do with water in the block when winter comes? Break my block I guess. Looks like I need an overflow tank this summer after all. Last edited by In The Ten Ring; 05-29-2017 at 05:48 PM. |
Active Member
![]() Join Date: Feb 2011
This is the one that was mentioned,from a Monte Carlo or an el Camino. I ordered on line from a gm dealer,it was cheaper than buying it local. Just google the part # in the photo I attached.
#8 | |
could I use a stock windshield washer tank as an overflow tank?
OK, I got the tank installed.
Do I need to change the radiator 'cap'? I filled the radiator but fluid doesn't flow into the overflow tank when the engine is hot. thanks |
I got a 13lb cap for a closed system (not a lever vent style). Radiator full to the top, coolant bottle half way full. After a hot shut down, mine pukes a small amount into the bottle, as engine cools off it draws it back into the radiator.
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
#13 | |
I'll replace the 16# flip cap with s 13# non-flipper. I also had to fix the plastic tube at the bottom of the plastic tank. There was a sharp casting line right down the tube which caused a big leak. This replacement GM part was really low quality. |
So after a little bit of rework I finally have a good working system. Tank fluid level rises ~1" when the engine is hot.
13# cap works great! ![]() My WAG is that the coolant should stay slightly cooler (when under heavy load) because the radiator is now always full vs ~4" below the filler cap with the factory 'dump it overboard' design. |
#15 |
Is that the G-body tank?
#16 |
This is it: "OEM Coolant Overflow Reservoir Tank 78-87 El Camino Monte Carlo Malibu 14085692"
http://www.ebay.com/itm/OEM-Coolant-...4AAOSw65FXrgGg It's a fairly tight fit. The hood hinge just barely clears it. A slightly shorter tank would be preferable.......... IMO. |
#17 |
Well the price of convenience. Mine is lower but I had to put a lot more work into the installation. A fair trade off. I would have gone with the G-body tank if only I had known.
