06-03-2017, 10:10 PM | #101 |
Re: Johns 66
I did open the spray booth and got some things painted up. I also received mu brake booster adapter from Captain fab( Thanks John)
I test fit it to the firewall and then to the brake booster....I thought I was gonna have to make the holes a little bigger but it fit perfectly without any mods....So I got a coat of primer and the 2 coats of black on it....looks pretty good...... I also blasted the water pump...and now that I think about it I may just go ahead and get a new one....I thoroughly cleaned it but can you really ever clean it enough to ensure all of the sand is out of it...Not sure I want to risk it ally with the new motor |
06-03-2017, 10:21 PM | #102 |
Re: Johns 66
So all in all it was a pretty good day...got a lot of little things done...learned a good lesson concerning the alternator....
Now that I have the brake booster bracket I can now install the booster and get the lines run.....after that I am going to remove the gas tank and see what the inside looks like....I read somewhere that I can put a 24 gallon tank behind the seat and I think I have seen one on one of the many websites I have looked at over the past several weeks...so if this one is corroded then I ll replace it and run anew fuel line....might as well ensure no crude gets in the newly built carb while I am at it. It starting to come together slowly but surely...Still waiting on the gasket set to build the heater box....not sure what the hold up is on that but will check next week on that. |
06-04-2017, 12:20 AM | #103 | |
Re: Johns 66
Great build, subscribed, got the popcorn ready to learn
1966 Chevy C10 Not named yet, help! 1984 GMC 4x4 SB "The Hunter" My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705 |
06-04-2017, 12:40 AM | #104 |
60-66 Nut
Re: Johns 66
Glad to hear the package made it today....the booster bracket looks good
Yeah I took an alternator apart once.....about 40 years ago. Since that time the most I will do is remove the bolts so it can be clocked differently when needed. Otherwise I just go buy a used, new or rebuilt alternator.
06-14-2017, 04:27 PM | #105 |
Re: Johns 66
I believe I read somewhere on this site that the original engine compartment color was black satin. I did the my engine compartment with POR-15, and the satin looks pretty good.
Any update on the your 700R4? I've just gotten mine mounted, but not running yet. Would be interested in your experience in getting it operational. I bought mine from Bowtie Overdrive....you may want to download their installation manual for all of TV setup, and pre-drive checks. |
06-15-2017, 01:20 PM | #106 | |
Re: Johns 66
I have been gone for a week fishing...yeah I know but you gotta take a li time away...Went to Lake Fork, Texas to fish. Had a great time....but not much was done on the truck. Have a family gathering this weekend but am gonna get on it full bore next week. My brother in law, Randy, builds transmissions for a living so he is building me a 700R4 to save me some money, which is always good...last one he built for me was in an 85 chevy pickup...had over 500k miles on it and still going strong. I am hoping by next weekend that the motor and tranny will be set in it and ready to fire it up.....but am STILL waiting on the gasket set for the heater so I can put it back together...... |
06-25-2017, 10:07 PM | #107 |
Re: Johns 66
Well its been a few days since I have posted anything on he ole truck...took a little fishing trip to Lake Fork Tx...had a great time.....
BUT not time for some pictures of things that I have gotten done over the past few days. Finally got the gasket set for the heater and put it back together...YAY!!!! Sprayed the manifolds in the ole rattle can spray booth what I thought was an aluminum color......seems odd looking to me but will put it on the motor and see how it looks. Got the power brake booster installed and the brake lines ran......I will paint he master cylinder in the coming days...mainly been working on the motor. |
06-25-2017, 10:25 PM | #108 |
Re: Johns 66
I did get my grommet set in and have installed a few of them already, I was trying to get the windshield washer motor changed and of course the great parts place sent me the wrong one so now I have to try and get it exchanged.
I did get the motor ready tonight to paint...got everything smoothed down and a good coat of primer.....Plan on trying to spray it Tuesday after work, but I gotta buy some parts before I do that. I am buying a new water pump instead of using the old one...think that is wise. I tried to figure out how to run the wires tonight and think I have a pretty good plan on how I am going to run them....Yelmer sent me some pictures of his motor so it gives me a good reference of what should be painted what color. Ill run to the parts house tomorrow to get all the needed supplies to make the motor run...oil, antifreeze plus, wires etc.....sure that's gonna be a pretty penny but hey...its all good |
06-25-2017, 11:15 PM | #109 |
One foot in front of the other
Re: Johns 66
Some good progress.
07-01-2017, 07:10 PM | #110 |
Re: Johns 66
Well Sports Fans FINALLY got to put some color on the motor....Today was a pretty day..NO RAIN and I was able to get the motor sprayed. This is the first time I have ever painted something with a spray gun and not rattle can. It was actually not too bad once I figured out how to mix the paint....I just sprayed thin coats until I got it where I kinda liked it. After I got done, cleaned up the gun I did find one light spot but I think it will be ok since the Harmonic balancer will cover it up... you can see it in the last picture...not too noticeable but none the less I still see it.
The funny thing is that Depending on what direction you are looking at it and the light source depends on what color it appears to be,,,,It looks darker a little bit in person...guess the pictures make it look lighter |
07-01-2017, 07:17 PM | #111 |
Re: Johns 66
Now here is where I am gonna try something......Hopefully it will come out as good as it looks in my mind.
So here is what I am thinking about...The motor does have some black on it, air cleaner a couple of brackets etc.....So in my redneck mind the valve covers while they look good do look a little bland all green so I am going to attempt the paint the script Chevrolet letters on the valve cover black...I am really unsure how I am going to accomplish this as of now.....I thought about getting a paint pen and trying that or a small brush and trying it by hand. But if I can pull it off I think it will look good...I know its not original ...But is should have been ..lol Don't think I have the patience to try and tape the script off...will just have to see |
07-01-2017, 09:16 PM | #112 |
Re: Johns 66
You are making nice progress. Engine looks great and I think the painted script on the valve covers would be a nice touch.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
07-01-2017, 11:21 PM | #113 |
Re: Johns 66
Motor looks great to me.
I've seen script painted with fine tipped brushes. |
07-01-2017, 11:49 PM | #114 |
60-66 Nut
Re: Johns 66
Looks good
I would run a piece of tape along the bottom edge since it is straight. This will give you a place to run your brush off of when coming from each letter.
07-02-2017, 09:30 AM | #115 |
Re: Johns 66
Like that color! Looks just like the paint I used on my gmc v6!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-02-2017, 09:04 PM | #116 | ||||
Re: Johns 66
I have to thank Mike Remley ( Yelmer) for giving me the correct paint color...Its hard to tell if its the exact color since it was mixed in 2 different states but its really close in my mind More pics to follow from todays efforts |
07-02-2017, 09:20 PM | #117 |
Re: Johns 66
Well today my intent was to set the motor back in the truck..notice I said intent...Little did I know that I own a Super Rare truck that no one carries parts for....those super secret parts like MOTOR MOUNTS..>Really no one carries motor mounts these days....So kinda hard to set the motor back in with no motor mounts.
Mike sent me some pictutres of his motor for reference and has been great at helping me with some of the harder parts that I need like the water pump bypass hose fitting which is an 87 degree fitting and things like that...Ironically no one at any parts store locally has a clue about anything that does not come up on their computer screen. Tomorrow I am going to Summitt Racing in Atlanta in hope of finding some of tehse super rare parts ( motor mounts) plug wires etc....hopefully my trip will be worth its since its about 2 hrs from me. So I decided to paint the script after I put everything on the motor I could. The results were mixed and I'm unsure if I will keep them as they are or sand it down and start over...I know its not a show truck and I'm gonna drive it but I do want it to look right when the hood is opened. So the first couple of pics are my hand with a brush and paint...I tried to use a paint pen at first and that simply wasn't working...so I tried a brush...lets just say that my hand is not as steady as it once was.....After that I decided to try and tape the script off and spray it with rattle can paint....It turned out ok...if you can call it that put it was thicker than the other side and some did run under the tape..... So my choices are to leave it be, try and tape the side I didn't to make them match a little better or simple blast them clean again and start over......but anyways here are some pics of what I did today..... |
07-02-2017, 09:27 PM | #118 |
Re: Johns 66
I did get everything I had for the motor on it, plugs manifolds, fan, alternator, belt...Carb was just sat on there to see how it would look....distributor was set in place since the first piston was TDC. I did fool around with some of the wiring today and realized that it has been modified from original since an HEI distributor was installed...I'm gonna get some acetone and clean the wires, re-tape them and make them look a little more presentable, fix some areas that need to soldered and heat shrink placed on the.
07-03-2017, 04:26 PM | #119 |
Re: Johns 66
Engine is looking great!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
07-07-2017, 12:41 PM | #120 |
Re: Johns 66
Well I got to a stopping point and had to sit down and order parts..I went to Summit Racing in Atlanta and got a few things but was really disappointed that I couldn't find the things I needed..Summit has a lot of "Pretty" stuff but not what I needed.
I was able to find the water pump bypass fitting on Ebay from a very nice man...I was also able to get the GM part number for it and a place to buy them if anyone needs that part...Ironically it goes on a 63-68 Corvette but its the same fitting that cam on the truck... So yesterday I ordered a BUNCH of stuff from LMC, American Classic Trucks, and Del City..Del City sells electrical supplies. I did order a new gas tank and sender while I was at it....It is a 24 gallon tank that fits behind the seat...like I said earlier I plan on driving this truck so 24 gallons means I will be able to cruise for awhile. The other issue I am having is finding a good 700R4 core for Randy to build...we found 3 so far but the cases were bad and not rebuildable. My plan now is to get the motor set back in this weekend and get the engine bay buttoned up until I can get the tranny etc..installed and here my baby run. Im still contemplating redoing the valve covers...gotta figure out a good way to do them so they look good..... AND of course am still looking for an original steering column...I have learned that a C20 would be a perfect fit especially for the tranny I am using but at this point as long as it is an original steering column I will make it work...maybe soon I will find one. |
07-07-2017, 01:46 PM | #121 |
Re: Johns 66
YOLO did have a column
http://67-72chevytrucks.com/vboard/s...d.php?t=741636 |
07-07-2017, 11:04 PM | #122 | |
Re: Johns 66
07-07-2017, 11:13 PM | #123 |
Re: Johns 66
Well Boys and Girls it is funny how life works sometimes....I contacted YOLO about a steering column he has and was thought to be an automatic steering column but it turned out not to be so I was kinda bummed out....
I have been talking to another forum member for months about a steering column....GMCNUT ( Steve) who coincidentally lives in Alabama...So after I found out that YOLOs wasn't what I needed I texted ole Steve on the off chance he may have one...... Low and behold he had one....After work I drove about 2 hrs to his place, still skeptical UNTIL I arrived....Yes Sir...I now have a 1966 Automatic Steering Column...It is for a power glide but I think I can make it work...don't really care about low anyways...long as it will go in drive I am good to go...pictures aren't that great since I took them when I got home but you get the drift...... ALSO I was able to get a new cluster that has the original factory tach in it...Super Pumped about that......So here are some pictures of what I got. I was also able to upgrade my radiator baffles..Steve was very gracious to me....Super nice guy and very knowledgeable...If you are looking for original parts...chances are Steve has them |
07-07-2017, 11:26 PM | #124 |
Re: Johns 66
While I was t Steves I did hae a chance to check out his collections of trucks and parts...he has a ton of stuff and also has some pretty rare parts, and I mean rare parts...he has a lot of NOS parts and I was amazed at what he had,,,,Although he wasn't willing to sell the NOS stuff it was still neat to see original unmolested parts...brand new 1966 stuff
The trucks below are all original trucks. The key thing about these trucks are they are pretty rare. Each truck is highly equipped...Factory Auto, Power Steering, Brakes, A/C etc...you get the drift....I had never seen a trucks like this.....He also has I think a 58 or 59 Double Deluxe truck......he drives daily.....all original...and no he wouldn't sell it either..lol I tried So Enjoy 1963 1966 1966 GMC 1961 Chevy C10 and the Apache He had several more but these were the main ones that I liked. |
07-08-2017, 08:58 PM | #125 |
Re: Johns 66
Well back in the ole garage today....Today was a day with big intentions but ended with a reminder that this truck is 51 years old....and anything 51 yrs old is not gonna be perfect...
So first for the good part of the day...I got the newly acquired automatic steering column installed....went a lot better than I thought...while the main shaft is fastened the steering wheel was just set on there for pictures......I think it is gonna work out just fine....of course it will need to be painted but that is for a later time. |
