Old 06-15-2017, 10:30 PM   #1
Mattchu60
87 TBI almost out ran out of gas, now wont run.
Well I feel like a fool as I type this. I drove 200 miles today to pickup a camper. Truck pulled it great, no issues, wasnt even working that hard. 6 miles from being home after 4 hours of driving, I was almost out of gas- I was at the 1/8 mark on the gauge. I KNEW I should have stopped and filled it, but i was hot and sweaty (95 out and no A/C) and I wanted to just get home.
I went up a hill and I think all the gas ran to the back of the tank, gauge dropped to empty and she started sputtering and chugging 10 secs later. I quickly pulled over, shut it off. I got some gas in a jug and filled it up, probably put 4 gallons in.
Wont start. sat there for over an hour and tried to get it going - if i pump the gas it'll start and chug, chug chug then die. I can hear the tbi fuel tank pump clicking on when I turn the key on. I don't think its dead.
Anyways. I ended up pulling it the rest of the way home. I'll look at it tomorrow, right now I'm too frustrated and tired. Going to try cracking the lines- my hope is there is just air in the system but not really sure - my thought is since the pump is a "Pusher" it should clear that out.
Any thoughts on what to look at tomorrow? this really is bad timing as I'll be gone all weekend, was hoping to use this next week.
Mattchu60 is offline   Reply With Quote
Old 06-15-2017, 10:50 PM   #2
Mattchu60
Re: 87 TBI almost out ran out of gas, now wont run.
And to add insult to injury, when I pulled the truck home, my wife forgot to put it in "N" and left it in park. Pulled her about 30 ft at 5-10mph, looked back and saw it bouncing. Hoping nothing too badly damaged in the trans now.
Old 06-16-2017, 06:46 AM   #3
Katrina/10
Katrina/10's Avatar
Does the pump run when you turn the key on?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-16-2017, 08:00 AM   #4
Mattchu60
I opened the door and can hear the pump come on for 2 seconds when I Key-On. I assume its working, but from what I am reading now - it could have been damaged where its hardly pushing any fuel.
I think i'll be pushing it into a corner of the shed for a while, I dont have the time to deal with it now.
Old 06-16-2017, 08:17 AM   #5
Katrina/10
Katrina/10's Avatar
That's a good sign. When you get a chance, take your air cleaner off and look for fuel spray while cranking.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-16-2017, 09:27 AM   #6
KrazyRay
KrazyRay's Avatar
Try changing the fuel filter. It may have got clogged up with the debris from the bottom of the tank.
KrazyRay is offline   Reply With Quote
Old 06-16-2017, 11:21 AM   #7
DieselSJ
^^This^^
Next step is to rent the fuel pressure check gauge from your local chain auto parts and check your fuel pressure.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-16-2017, 01:54 PM   #8
50dan
Id say it's definitely a fuel delivery problem so I would check filter first them pull a line and check the pump or if there is a way to check fuel pressure do that. sometimes the pumps get weak.
50dan is offline   Reply With Quote
Old 06-16-2017, 03:40 PM   #9
Mattchu60
Put a new filter on - no change.
I have a pressure gauge which I will try to hook up later. Needs a new o-ring.
Old 06-17-2017, 07:47 AM   #10
cadillac_al
Too bad GM wasn't smart enough to put a pressure port on the truck. I think you have to guess or flip a coin or buy a fitting to check fuel pressure. The fuel pump does sound like the most logical culprit.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-18-2017, 03:35 PM   #11
Pontiac1976
Pontiac1976's Avatar
It may have air in the lines too. I would make sure the lines are clean & tank too. Try pumping line to make sure it does not air in them.
Good Luck let us know how it goes.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-18-2017, 06:02 PM   #12
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I have seen one blow off the hose in the tank after it sucked up some trash.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 06-18-2017, 08:19 PM   #13
Sabaka454
Sabaka454's Avatar
You need to check your fuel pressure
Sabaka454 is offline   Reply With Quote
Old 06-20-2017, 01:21 PM   #14
Mattchu60
I got my fuel pressure gauge on today, yep - pump is hardly pushing any fuel - only getting 2-3 lbs on the gauge.
Poured some gas in the TBI and she started right up. Guess its time to tear it apart.
Old 06-24-2017, 01:24 AM   #15
cjthompson
That's happened to me a time or 2 now..... minus the pulling in park..... both times it was the rubber hose between the pump and the sending unit. I'd drop the tank and look at it before you buy a pump.....
If you do change the pump, I found this forum very informative.
https://www.thirdgen.org/forums/tbi/...p-upgrade.html
cjthompson is offline   Reply With Quote
Old 06-24-2017, 08:45 AM   #16
cadillac_al
That's a bummer but now you know it isn't cool to run electric fuel pumps empty. They're wimpy.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
