Old 06-16-2017, 06:24 PM   #1
rustycars63
removal of generator battery control module
2005 5.3 harness trying to remove the Generator battery control module as I do not think it is needed in my 1949 Chevy truck . Any help will be appreciated .
rustycars63 is offline   Reply With Quote
Old 06-16-2017, 07:56 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: removal of generator battery control module
Bypass the wiring, have your tuner flash the ECM with a 2004 O/S. You won't lose anything you'd need in your swap, and it deletes all the GBCM functions.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-17-2017, 07:52 AM   #3
rustycars63
Thanks very much for your input will give this a try .
Old 06-17-2017, 11:28 PM   #4
ls1nova71
ls1nova71's Avatar
You will have to wire it like an '04 also. There aretwo wires that go to the PCM. You may also need an older alternator, the one with the flat plug. When I did my '06 with the round plug, even with it wired and tuned for an '04 it still defaulted to 13.8v.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-05-2017, 07:58 AM   #5
rustycars63
Thanks , i am side tracked on truck for the moment but will follow your advice , thanks again.
Old 07-05-2017, 02:55 PM   #6
Hart_Rod
Hart_Rod's Avatar
Mine defaulted to 13.3V (13.8V at the generator output), at least that's what my gauges are showing. I'm thinking about wiring the GBCM back in, as I see a pretty substantial (2V) when data-logging and going WOT and would like for the alternator to put out more voltage when the situation arises.
Hart_Rod is offline   Reply With Quote
Old 07-05-2017, 09:59 PM   #7
ls1nova71
ls1nova71's Avatar
I probably would if you have it. Seems to me it's a better way of controlling the alternator, and isn't really that much more wiring. It's a couple of power wires and some grounds, then the rest just go between the GBCM and the PCM so there's nothing really to be done. You will have to splice the serial data wire, but that's about it. Here's a schematic in case you need it. The schematic is two pages, even though it looks like one, so that's why it looks funny. I cant put them all on one page and still be able to read them.
Old 07-06-2017, 09:01 AM   #8
Hart_Rod
Hart_Rod's Avatar
Thanks Eric!
Old 07-06-2017, 11:42 AM   #9
rustycars63
Now I have more to think about , thanks for all the input that has been shared .
Old 07-11-2017, 07:50 AM   #10
rustycars63
Any one actually using gbcm on their trucks and are there any issues ?
Old 07-16-2017, 05:47 PM   #11
Daaaanz67
Doesn't, this require a BCM for the GBCM to work?
Daaaanz67 is offline   Reply With Quote
Old 07-16-2017, 05:53 PM   #12
rustycars63
That,s what i thought also , need more input , thanks
Old 07-16-2017, 08:35 PM   #13
dayj1
For a Gen III GBCM module, a BCM is not required. Here'e the info about how it works straight from AC Delco: https://acdelcotechconnect.com/pdf/imtn_V12I305.pdf
dayj1 is offline   Reply With Quote
Old 07-17-2017, 07:27 AM   #14
rustycars63
Thanks, any special wiring or is the information provided in previous posts the way to go ? Thanks for all the input.
Old 05-21-2018, 08:08 AM   #15
rustycars63
Need help I am trying to reinstall gbcm on 2005 5.3 the part number for the plug is a Delphi pa6-gb20-gf10 can not get this number to come up anywhere, also need the part number of the pins that go to plug. Can any help me find them. thanks for your help.
Old 05-21-2018, 09:39 AM   #16
dayj1
Most of the connectors will be in this catalog. Once you have the correct part numbers, many online vendors will carry them. I generally use mouser.com https://www.powerandsignal.com/docs/...%20Catalog.pdf
Old 05-23-2018, 12:24 AM   #17
71cadc10
71cadc10's Avatar
that string you listed on the connector, is not the part no. It is the recycling code for the plastic...FYI.
The Delphi p/n would be something like 6-8 digits just numbers.
do you have a pic of the connector maybe I could help ?
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 05-23-2018, 07:40 AM   #18
rustycars63
Thanks , for all the help looks like help desk is giving me 13545282 or new number 13545282 as plug number after sent photos to them. Customer service at Mouser .
Old 05-23-2018, 10:24 AM   #19
ls1nova71
ls1nova71's Avatar
If you're younger than around 40, you probably wont get this, but I've read this thread several times and every time I see this post, this is what I think of... https://youtu.be/Pj-qBUWOYfE
Old 05-23-2018, 11:19 AM   #20
rustycars63
I will have to admit that I am a slow mover on my truck will pick up the pace soon .
Old 05-23-2018, 11:51 PM   #21
Wildkarde
Eficonnection.com is a great source of LS connectors and they offer most of them as pigtails.
Wildkarde is offline   Reply With Quote
Old 05-23-2018, 11:59 PM   #22
dayj1
You probably already know this, but, just in case, the part number you have is for just the plastic housing. You still need the terminals for the appropriate wire size that you're using, the seals, and, possibly, crimpers to attach the terminals to your wires if you don't already have them.
Old 05-24-2018, 07:03 PM   #23
Hart_Rod
Hart_Rod's Avatar
I hooked my GBCM up per the instructions/wiring diagrams. Nothing changed, still defaulting to 13.8 V. Does something have to be updated in the tune? Is there a way to troubleshoot the GBCM? TIA
Old 05-25-2018, 08:22 AM   #24
rustycars63
Did you hook up the Blue wire , engine on signal , some say to store it as its not needed , but, does this control gbcm. The link to the acdelco information is no longer available that i can find. Just thinking out loud.
Old 05-25-2018, 09:34 AM   #25
Hart_Rod
Hart_Rod's Avatar
No blue wire in the harness that came with my GBCM. I wonder if I have to turn on the "L" terminal in the tune system options?
