Old 04-11-2004, 02:13 AM   #1
swervin ervin
You get what you pay for
swervin ervin's Avatar
My rear disc conversion
Well today, sore fingers and all, I started stripping down all the brake stuff on the truck. I couldn't take not doing anything any longer. I haven't got the plans for the rear disc conversion yet, but I have a good idea of what I'll be doing.
I ordered my disc/disc master cylinder and combination valve. I found out I don't need a new booster. I took off the master cylinder and combination valve, removed the drums and brake shoe stuff. Took off the rear end cover and drained all the grease. Probably Monday I pull the axles and remove the backing plates.
The plans show the caliper mounted at the top, which from all my reading won't work right. The bleeder fitting needs to be at 12:00 in order to be able to bleed all the air out of the system. I plan to rework the mounting brackets so I can mount the caliper like it should be, which is just about horizontal, or like the fronts.
I've seen where a lot of folks have trouble with brake bias and low pedal when converting to rear discs. In order for the rear discs to work right, you must use a disc/disc master cylinder and combination valve. This solves the problem of fluid level for the rears and the disc/disc valve solves brake bias problems. Also a disc/drum master cylinder don't have enough pressure for rear discs. A disc/drum combination valve will cause the rear discs to drag because it has a built in residual valve which is needed to keep pressure on the brake shoes so they will stay close to the drum.
Not sure yet on what calipers I will use. I know the ones for the Sevilles have a built in park brake but I don't care for having to use the park brake everytime I park the truck. This is the way these calipers adjust the brakes. A standard caliper like the fronts are self adjusting, but have no park brake feature. I don't ever use a park brake so I might just go with a front style caliper. I found out if you do use Seville type calipers and don't use the park brake feature, it will quit working. I believe I will need to resize the axle flange so the rotor will slide over it. I'll find out more on this when I get the plans and dimensions.
Can't wait to get started on the brackets. I love to fabricate stuff from scratch. Having plans will make this process easier. I'll keep everyone up to date on how everything goes.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-11-2004, 02:29 AM   #2
C-10volvo
C-10volvo's Avatar
i am interested on how this turns out for you, keep us updated on what you end up putting on. its been awhile since i've seen you around here!!
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 04-11-2004, 02:30 AM   #3
apstguy
LED King
apstguy's Avatar
I don't think it is a good thing to get rid of the e-brake because you don't use it. Remeber, if you loose all hydraulic pressure, you're screwed. I've had it happen to me and would never drive a car without an e-brake. That is why it is called an EMERGENCY brake. That is just my 4¢!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 04-11-2004, 02:39 AM   #4
swervin ervin
Tyler,
you are right. I've had a brake hose bust before and had to drive home about 20 miles with nothing but an e brake. I'll probably investigate more into the Seville calipers when I get the plans on everything. I don't guess it would kill me to use the e brake when I park, but it could kill me not to have a e brake at all.
Old 04-11-2004, 03:55 AM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
Actually, it's called a parking brake. It's purpose is not for emergency situations but it works.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-11-2004, 12:18 PM   #6
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Mike,
Having owned an 85 Seville for over 5 years I can tell you that the rear disc system on them are great when they are all set up and bled correctly. But, they can quickly become a nightmare when they aren't. Unless you are the type of person that uses the E-Brake on a regular basis the rear calipers will give you more problems than it's worth. Just my .02 .
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 04-11-2004, 12:29 PM   #7
RockHQ
ROCKET POWER!
RockHQ's Avatar
Mike, FWIW, you needn't really worry about the bleeder screw positioning. When you need to bleed the brakes just unbolt the calipers, position them correctly and use an old rotor or something of the same thickness in between the pads to keep the piston from coming out. I know it's not very convenient but it works.
RockHQ is offline   Reply With Quote
Old 04-11-2004, 12:37 PM   #8
RockHQ
ROCKET POWER!
RockHQ's Avatar
BTW, which master cyl are you going to use?
I'm going to run rear discs, but i'll be using the hydroboost booster which i believe limits the available master cylinders to, uhh.., one type.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
Old 04-11-2004, 12:56 PM   #9
swervin ervin
You know what? Seville calipers are expensive. I found them for $280.00 for the pair. This includes calipers complete with the e brake parts, pads and bolts. This is the best I've found so far. Still undecided about using them. I'm just not one to use the park brake all the time and from what I read and hear, if you don't use it on a regular basis, it quickly messes up the calipers.
I've read so much on this, my head hurts. I went with a new master cylinder and combination valve from mpbrakes
I read somewhere that 77 Lincoln Continental rear rotors are 5 on 5 and will work like a charm. Other than this, you will have to redrill others to make them work.
Old 04-11-2004, 01:39 PM   #10
bigblock73
yeller
bigblock73's Avatar
Mike, yes, the mid to late 70's Lincolns had rear disc brakes and a 5 on 5 BP...thay also had 9" rears.
I do not know the with of the assembly, but if you could find one and it was close in width...that might be a good upgrade. The nine inch rears are easier to change gears, and are stronger than your 10 bolt (I think you have a 10 right?)
I am thinking about doing it, but my main concern at tis point is to get the truck finished...I can always upgrade as time and money allow.
bigblock73 is offline   Reply With Quote
Old 04-11-2004, 02:27 PM   #11
Jonboy
Slots go on anything!
What about 77-up Devilles and Fleetwoods. They had the 5 on 5 pattern, rear disc brakes, and I believe my 78 Fleetwood still had a 12 bolt. You could probably buy a whole car for less than 2 calipers.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-11-2004, 06:03 PM   #12
dmec
dmec's Avatar
i have done this cad conversion. the axle flanges require turning down on a lathe to fit inside the rotors. the rear calipers consist of a piston within a piston. the outer piston is for braking. the inner piston is mounted on a screw and controlled by the e brake cable. that is why you have to set e brake to adjust rear brakes. the lever turns the screw which takes the slack out of the inner piston which then reacts on the outer piston. i planned on using the cad master cylinder and proportioning valve. never got a chanch to test. sold the rear end before i could get it installed. since then i have aquired the rear disc set up from a 92 caprice. the rotors fit over the axle flanges without lathe work. havent started on that installation yet. i think the 92 caprice rotors with 77/79 cad seville calipers and home made bracket would work well. i can get rebuilt cad calipers for $200 with no core.
dmec is offline   Reply With Quote
Old 04-11-2004, 06:57 PM   #13
rage'nrat638
rage'nrat638's Avatar
wilwood disc's with e-brake
rage'nrat638 is offline   Reply With Quote
Old 04-11-2004, 07:10 PM   #14
1FaastC10
1FaastC10's Avatar
Mark, does that caliper have dual bleeders, or are my eyes playing tricks on me??
1FaastC10 is offline   Reply With Quote
Old 04-12-2004, 01:02 AM   #15
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Mike don't you have to have the E-brake connected for inspections purposes? I know we do here in Texas.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-12-2004, 01:56 AM   #16
low 84
low 84's Avatar
most likely so they can be mounted in different locations. the bleeder needs to be at the top because thats where the air rises. so with one on each end, the calipers can be mounted on the back side like they are or the front side
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-12-2004, 10:26 AM   #17
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It might also allow you to use the same caliper for the left or right side. That is just a guess...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-12-2004, 11:20 AM   #18
Grim Reaper
The 76-78 Caddies will fit the thick vented rotor used on the fronts of 4x4's That's why they are so popular. The 81 up is actually a better set up and easier to make the parking brake function BUT it will not fit a front vented front disc unless you maching half or more of the pad off.
Best prices I found was Advance Parts. That is eating the Core charge.
I have a 90's 10 bolt disc assembly. It's a slick set up but would require some of the same work with machining the flange to work. The mounting flance for the backing plte and caliper mount are also turned 45degrees to what a 12 and 80's 10 bolt are.
The parking brake is sweet. It's a drumbrake withing the disc hat. Somebody has a complete 10 bolt with the disc set up and 3.73 gears for sale on CK5 right now. ANother couple years and they will be showing up at the pick a parts for decent prices. Right now they are getting a arm and leg.
Hay check with your local GM dealer. When people blow the granade locker and trash the axlehousing they replace the complete axle including the brakes. That's where the one I have came from. it was in the Dealers dumpster and some dumpster divers got it for scrap for their meth habit. I noticed it on their truck and I talked them out of it when they were diving the dumpster here.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 04-12-2004, 08:13 PM   #19
87Silvy
87Silvy's Avatar
There's a '85 running around here that has a four wheel disc conversion.
1987 Chevrolet Silverado
2005 Chevrolet Silverado
87Silvy is offline   Reply With Quote
Old 04-13-2004, 02:30 AM   #20
Grim Reaper
Ohh yeah I just reread you post. Stock master has more then enough pressure. It has a bias problem because it's WAY to much brakes for the rear. If I didn't adjust the bias on my truck I'd lock 35's EVERY time I tried to stop...that's stock master on there. 76-78 Caddie had rear anti lock brakes. .
The problem with the bias lies in the disc size and the piston diameter. On a modern car you will notice that the rear dist is smaller then the front and smaller calipers are used most times. The smaller disc and calipers help adjust the bias. I needed to pull about 30% out with a adj PV to get my truck biased.
2lb residual valve in the rear circuit will firm up the peddle.
I modified the Combination valvel into a distribution block with presure fail indicator.
Here is a little write up that will tell you how.
Grim-Reaper
