Old 04-11-2004, 02:26 AM   #1
ocbaud
Garage Queen Material
quick question now !!!! HELP!
Small block Chevy - These engines have used three different timing pointer locations. Pre '69 engines have the TDC mark 2° to the left of the keyway centerline. The '69 to '85 dampers have the TDC mark 10° to the left of the keyway centerline. The 1986 to 1991/1992 have the TDC mark 40° to the left of the timing mark. All of our SB Chevy dampers, as well as all other aftermarket dampers, use the 10° TDC position. Our 6.75" diameter models have two TDC marks, one that is 10° and one that is 40° to the left of the timing mark. If you have a pre '69 vehicle you can use one of the aftermarket bolt-on timing pointers to align correctly with the timing marks on our dampers.
thats quoted from http://www.professional-products.com
they made my balancer. so, tell me right now if my balancer is correct for my pointer i have
ocbaud is offline   Reply With Quote
Old 04-11-2004, 02:30 AM   #2
low 84
low 84's Avatar
i don't remember where the keyway points at TDC. i'm assuming it points at 12 oclock and if so then your pointer is in the 40 deg position. so if you have the 6.75 balancer then it should be marked for the 40 deg. if you have a larger diameter then your balancer isn't marked for the location of your pointer
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-11-2004, 02:31 AM   #3
ocbaud
8" balancer is what i have
Old 04-11-2004, 02:35 AM   #4
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Refresh me which are you using?
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 04-11-2004, 02:36 AM   #5
ocbaud
model #80002
8" balancer
i'm also using a jegs timing pointer that is at the 2:00 spot on the timing chain
Old 04-11-2004, 02:58 AM   #6
toytruck
toytruck's Avatar
You are ok with that pointer.
Old 04-11-2004, 03:02 AM   #7
ocbaud
i guess i'm happy and sad. sad because its more work for me to do to figure out what is wrong.
Old 04-11-2004, 03:02 AM   #8
low 84
low 84's Avatar
how do you figure? according to the company his balancer is marked for a 10 deg pointer. 3 oclock would be 90 degrees, his pointer is at 2 oclock so that would be well above 10 degrees where it states his balancer is marked
'05 1500 Crew Cab
RIP
Old 04-11-2004, 03:03 AM   #9
ocbaud
i just read on their site that "all of there balancers are compatible with aftermarket "bolt on" timing tabs/pointers"
Old 04-11-2004, 03:07 AM   #10
toytruck
toytruck's Avatar
I'm going to rethink this tomorow its 2:30am and my brain is shutting down. Sorry.
