Old 06-17-2017, 12:39 PM   #1
shp4man
shp4man's Avatar
What extra parts needed to install a 283/327 radiator in a 230 truck?
The bottom brackets are different, right? How about the top bracket, hoses?
Really want the bigger radiator because I'm working on an A/C install. .
Thanks.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 06-17-2017, 01:38 PM   #2
Fastest32
Fastest32's Avatar
Re: What extra parts needed to install a 283/327 radiator in a 230 truck?
I need this info too. Are you installing a/c on an inline 6 motor?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 06-17-2017, 01:58 PM   #3
shp4man
shp4man's Avatar
Yep. It's hot out there!
Old 06-17-2017, 11:36 PM   #4
Captainfab
60-66 Nut
If you currently have the small I6 radiator that sits out from the radiator support and down on the lower step of the crossmember, you will have to change a few things. First you will need the wider saddles for the radiator you are going to purchase. These will bolt to the radiator crossmember on the top, flush with the top of the frame. You will need the correct top hold down for the width of the radiator core you buy. Next you will need to remove the shrouding between the radiator support and the I6 radiator and replace it with the pieces for the V8 style radiator.
Old 06-18-2017, 01:02 PM   #5
shp4man
shp4man's Avatar
Thanks, Captain!
Old 06-18-2017, 05:48 PM   #6
Lugnutz65
Lugnutz65's Avatar
Thanks.
I made this swap. I have a radiator in the V8 position with an inline 230ci. My parts truck had a V8 Harrison radiator which I kept with my first engine swap. I moved the saddles from the lower part of the rail to the top part of the rail. The square holes were already there. The metal and rubber that goes around the V8 radiator is NOT the same as the metal pieces that channel air for the tall narrow style inline 6 radiator. See photos.
I've removed the factory fan since these pics were taken. The metal blade did not clear the brass fitting for the tranny cooler - so beware of that possible issue.
The top radiator clamp is also shorter since the V8 radiator sits closer to the radiator core support.
When I needed to swap to a new radiator (new aluminum) I found that my original lower saddles and top clamp were not wide enough, so I had to do some fabrication of both the lower saddles and the top clamp.
For me, the V8 radiator position allows for a little more room to add an electric fan and a little more working room too.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-18-2017, 08:26 PM   #7
Lugnutz65
Lugnutz65's Avatar
These are the V8 radiator surround pieces I mentioned above.
Old 06-18-2017, 10:58 PM   #8
shp4man
shp4man's Avatar
Great info and pics. Thanks, dude!
