Old 06-17-2017, 06:25 PM   #26
Advanced Design
Advanced Design's Avatar
Re: Barger's 79 FJ40
Wow, you have been busy!
What did you paint the chassis with? Looks good!
Advanced Design is offline   Reply With Quote
Old 06-18-2017, 09:09 AM   #27
reaper71
reaper71's Avatar
Thanks Doug!
It is just a satin Chassis black
Mark
reaper71 is offline   Reply With Quote
Old 06-24-2017, 08:03 AM   #28
RockinKees
RockinKees's Avatar
That is a major difference!!
Looks really good!
We know you are busy, even if you don't post all the pics we need....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-24-2017, 08:59 AM   #29
reaper71
reaper71's Avatar
Thanks Kees!
I have been very busy on several projects and trying to squeeze all of them in to get work done. And then trying to remember where I left off the last time I worked on them!!
Mark
Old 06-25-2017, 03:57 PM   #30
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by reaper71 View Post
Thanks Kees!
Mark
You're not alone there! I tend to thrive on juggling projects... This 40 is coming along nicely! I have 68 waiting for its turn in the shop.
Frizzle Fry is offline   Reply With Quote
Old 06-26-2017, 09:30 AM   #31
reaper71
reaper71's Avatar
Thank's!!
It's coming along (slow but steady) this one will be restored back to O.E.
It will be the 2nd one I have restored and 3rd total that I have done work on.
Mark
Old 09-15-2017, 10:08 AM   #32
reaper71
reaper71's Avatar
Hey Guy's back with an update:
Yes I am still working on the FJ and making alot of progress just haven't been posting.
pic#1. engine before
Pic#2. engine before
pic#3. engine after all seals and gaskets replaced and painted.
pic#4. another shot.
pic#5. Engine and trans finished and back in the chassis
Old 09-16-2017, 06:11 AM   #33
RockinKees
RockinKees's Avatar
Looking good Mark!!
Cheers!! Kees.
Kool Guyz CC
Old 09-16-2017, 08:55 AM   #34
reaper71
reaper71's Avatar
Update:
Pic #1. Found a shop close to us that does sandblasting and powdercoat for a really good price. Body loaded
Pic #2. Body after blasting. Came out super nice!
Pic #3. Some other parts
Pic #4. When I got all the parts back I spent the rest of the Day getting them prepped for Epoxy Primer followed by High Build primer.
Pic #5. The parts all shot in Epoxy primer. The bare spots and with tape are areas that have rusted spots that will need attention.
Mark
Old 09-16-2017, 03:25 PM   #35
RockinKees
RockinKees's Avatar
That's a shop full of parts!!
It is a pretty solid car by the pics to see?
One question, off topic, you don't have to answer...
Is this your daily job?
Or just "just" a hobby?
Keep the pics coming Mark!
Cheers!! Kees.
Kool Guyz CC
Old 09-16-2017, 03:53 PM   #36
Rickysnickers
I like that trolley system you have the body on. That's really well thought out. How much weight can it hold?
Old 09-17-2017, 09:16 AM   #37
reaper71
reaper71's Avatar
Kees, Yes the body was pretty solid (kinda rare for these) I will be showing all the metal work that needs to be done.
As for your question, Yes this is what I do everyday!
Mark
Old 09-17-2017, 09:21 AM   #38
reaper71
reaper71's Avatar
RickySnickers, The trolley system really helps for lifting things by yourself (alot safer and dont have to buy beer to bribe your friends lol) Dad put this up when he built the shop 20yrs ago or so. Dont really know how much it can really lift but the hoist's are 2ton each, so a fair amount.
Mark
Old 09-17-2017, 09:33 AM   #39
reaper71
reaper71's Avatar
Update:
Pic #1. This is the rear sill that was the worst section of the body (the outer skin was removed in this shot)
Pic #2.The section on the left needs to be cut out, so it will be hand made.
Pic #3. This was after all the rot was cut out. (If you look close the right side corner was cut out and needed to be replaced)
Pic #4. Close up of the corner, the reason I cut all this out was the brace that goes in behind it gets welded to this and had rotted through and took out the lower lip as well.
Pic #5. The new patch I made.
Mark
Old 09-25-2017, 08:13 AM   #40
reaper71
reaper71's Avatar
Update:
Pic #1. New corner tacked in
Pic #2. The new rear brace (ties the back end together)
Pic #3. The Drivers side patch.
Pic #4. The rear sill installed
Mark
Old 09-25-2017, 08:21 AM   #41
Advanced Design
Looks good! Nice fix Mark.
Old 09-26-2017, 08:12 AM   #42
reaper71
reaper71's Avatar
Thank's Doug
Old 09-27-2017, 07:40 AM   #43
RockinKees
RockinKees's Avatar
Great work!!
As always.
Cheers!! Kees.
Kool Guyz CC
Old 09-27-2017, 08:25 AM   #44
reaper71
reaper71's Avatar
Thanks Kees
Old 10-07-2017, 08:41 AM   #45
reaper71
reaper71's Avatar
Pic #1. The bottom lip was all hand made as well to look factory.
Pic #2. This section had a lot of rot so it needed to be cut out, the reason for the rounded ends is to reduce the chance of cracking in the corners.
Mark
Old 10-07-2017, 10:59 AM   #46
Advanced Design
Good idea with the rounded corners. And I've noticed square corners burn out easier.
Nice finishing on the bottom lip.
Old 10-08-2017, 09:28 AM   #47
reaper71
reaper71's Avatar
Thanks Doug
Old 11-23-2017, 09:32 AM   #48
reaper71
reaper71's Avatar
Hey Guys, its been awhile for an update.
Yes I have been working on it just No pics, so here we go.
Pic #1. The filler strip all welded and finished.
Pic #2. This is the Drivers side front section right behind the fender.
Pic #3. All repaired.
Pic #4. Drivers side rocker panel needed some work,
Pic #5. All repaired.
Old 12-05-2017, 03:53 PM   #49
RockinKees
RockinKees's Avatar
Steady as it goes
Looking good!!
Cheers!! Kees.
Kool Guyz CC
Old 12-10-2017, 10:42 AM   #50
reaper71
reaper71's Avatar
Thanks Kees.
I found more spots that needed work.
Pic #1. Drivers side support.
Pic #2. The support was cut out so I could reveal the tub section to be repaired.
Pic #3. After repair was made, needs metal finish
Pic #4. The support repaired.
Pic #5. support all metal finished.
Till next time
Mark
