06-20-2017, 07:23 PM | #1 |
Help with outside mirror location
Could someone measure a truck for me, from the front edge of the door to the first mirror screw on each door. I'm putting the 67-70 style small mirrors on my 69 K/20, but don't have a truck to get Dimensions off of. All mine are 71-72 styles. Here's the mirror arm I'm using. Thanks
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
06-20-2017, 07:50 PM | #2 |
Re: Help with outside mirror location
It looks like 2-3/4 inch from the leading edge, and 2-13/16 from the top of the door skin.
06-20-2017, 08:25 PM | #3 |
Thanks for the info, can you measure the drivers side to, it should be different. The mirror is further forward.
06-20-2017, 08:26 PM | #4 |
Well at least they are different on the 71-72 mirrors
06-21-2017, 12:02 AM | #5 |
The Older Generation
Here is what mine measured..... The measurements are the same , the mirror arms are different lengths. LockDoc
06-21-2017, 12:34 AM | #6 |
Yes, that is interesting. I didn't know that about the different length arms. I went around to the driver's side and measured that and noticed they were the same, so didn't mention it.
06-21-2017, 12:59 AM | #7 |
I bought a set of mirrors like the ones you have. First thing I noticed was they were made in China. I hated those mirrors so bad. They looked great when the truck wasn't moving. Going down the highway, you couldn't see a thing the way they shook. To change lanes, you had to reach out and hold them from shaking to see if it was safe. I rode with someone who had the old original rusty mirrors and you can see everything fine. Good luck with yours.
06-21-2017, 02:26 AM | #8 |
I found lockdoc's pic last week to put a set of these on my 67'. They are after market as well, I've driven the truck quite a bit since then and haven't noticed any excessive shaking, in fact I'm quite happy with them.
Joe, something I do is put a dab of silicone on the backing plate before I install everything. That way if you have to take the mirror off the plate won't fall. It works excellent.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
06-21-2017, 06:03 AM | #9 |
I call these stick mirrors and they are the last of their kind on the 67-70s. GM always used asymmetrical mirrors like this. The early ones were solid rod, then came tube, which vibrates less. I call the 71/72 mirrors car mirrors since they are the same as car mirrors, only longer. Those are where they started being mounted in different positions due to being same dimensions, other than being reversed from each other.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-22-2017 at 07:30 AM. |
06-21-2017, 07:22 AM | #10 |
Thanks for all the info guys!!
01-11-2018, 11:21 AM | #11 |
I have an additional question concerning these. I just purchased these style mirrors as well as new doors. I'm getting ready to drill the holes for mounting them. Do you just drill a hole in the 16 gauge door metal? Is that all that holds them? I would think there would be some form of backing plate.
01-11-2018, 11:30 AM | #12 | |
01-11-2018, 12:05 PM | #13 |
01-11-2018, 12:12 PM | #14 |
Thank you. I didn't see them at LMC. Got a pair coming from GMCPauls.
01-11-2018, 12:18 PM | #15 |
I haven't looked inside my 68 doors yet but on my 64 the backing plates were already welded on the inside but there were no holes in the skin. I just had to drill the holes in the skin to match the plates. It's been too long; I don't remember how I did it to make them match.
01-11-2018, 12:44 PM | #16 |
The plates on the '67-'72 trucks weren't welded in. If it originally had that style of mirror, many times you will find the original plates in the bottom of the door. People just took the screws out and let the plates fall to the bottom of the door and installed different mirrors. Same thing with the sport mirrors. LockDoc
02-14-2018, 08:01 AM | #17 |
Collector of Projects
Has anyone used the black painted version from aftermarket suppliers?
I'm looking at the large square head for my 1972 K5 Blazer... |
03-18-2018, 08:30 PM | #18 |
did you have reinforcement brackets on the inside of the door?
02-13-2020, 10:17 AM | #19 |
Old member
I installed mine yesterday. I did find a backing plate inside the door but I decided to make new ones out of the leftover metal I had from the rear corner panel. The one I found was in pretty bad shape. I made a pattern off of it and installed lock nuts and washers. All Stainless steel.
The mirror arms are both the same length also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-13-2020, 10:22 AM | #20 |
Andy,
Did you think about hitting the interior of the doors with some OSPHO or other rust converter since you where inside there?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-13-2020, 10:31 AM | #21 |
Old member
Thanks to Doc's pictures he gives us all a starting point. He is using GM NOS mirrors though.
Doc's: NOS mirror = Drivers side is 2-5/8" from front of door to center of screw. arm is 9 1/2" long Passenger side Doc: 2 5/8" front of door with a 10 1/2" arm Mine: New after market = Drivers side 31/2". arm is 8" long Passenger side mine: 3 1/2" from door edge with 8" arm. But if you buy new aftermarkets they are not the same. I just lined the mirror head up to be even with the vent window channel bar in the door. This way your view is good on either one. The arms sit out far enough so the vent window is functional also. We will have to wait and see how they do driving it since I have no tag yet for it.
