Old 06-23-2017, 09:30 AM   #26
68is4me
68is4me's Avatar
Re: PB Stage 2 Deluxe Front Kit
Originally Posted by PBFAB.COM View Post
You had zirk fitting issues too? When did you order your arms? Was it recent? Please let me know. Like I said in my post above, we order those in bulk, so if there is an issue, we'll need to address it before we've got 100 sets of arms with a problem.
Brandon
I am sure that the holes on the arms were drilled just a hair to big. My invoice number was 8749 I think I ordered Dec early jan.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 06-23-2017, 09:39 AM   #27
68is4me
68is4me's Avatar
Originally Posted by Willie Makeit View Post
Brandon
I called and spoke to you directly. I asked for torque specs for the cross shaft nuts. You stated to me that Nathan was busy welding and you needed to speak to him and would call me back in 5 minutes with that information. I never rec'd that call. I eventually found a thread on this board where Nathan said that the nut should bottom out the crush sleeve bushing then go an additional 1/4 turn. That's what I did.
As far as the zerks, it wasn't the zerk fitting being undersize, the hole itself was oversize. As a machinist for over 25 years, it was fairly easy for me to spot the issue. Guys not familiar with metal working and proper tap drills may not realize the issue.
Not meant as a bash by any means. Some of the nicest components I've ever purchased and just wanted to point out my experience. A set of instructions on the control arm kit would go a long way to help explain some of the small things that pop up. Hope my input helps you guys improve your processes and products.
x2, Sounds exactly like I had written it. I was contacting you mostly through emails. I also asked for torque specs and I was emailed a basic copy of the instructions which wasn't much. I did what Willie did and found the info on this site.
I am not trying to give PB a bad name the products are outstanding, but they are lacking a bit in customer support. Including a good set of instructions would help a lot.
Sorry to the OP, for getting off track. Did you find all the parts within your budget?
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 06-23-2017, 11:18 AM   #28
PBFAB.COM
PBFAB.COM's Avatar
That's because I had not yet discovered that issue. After the multiple delays in shipping combined with not getting response to my questions, I didn't have a lot of confidence that i would get a reply to the Zerk issue.
no offense, but i honestly didn't have time to wait on you guys to "make it right." I had already waited approx 8 weeks on my arms after being told that it would be 3-4 weeks when i originally placed the order.
If i may, let me be blunt for a moment - i get it you guys have long lead-times, that was understood when I originally considered your products - but when one places an order & their confidence in a vendor based on the delivery information that was supplied by said vendor (aka: his word) at the time of order to discover afterwards that this information is false/not accurate, then it doesn't exactly leave one with a "warm and fuzzy" if you know what i mean.
Willie,
Totally get it. Sorry you didn't have a great experience. I'll try to do better if we have an opportunity in the future.
Brandon
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-23-2017, 11:22 AM   #29
PBFAB.COM
PBFAB.COM's Avatar
Thanks for the feedback. If you ever need anything in the future, please reach out.
Brandon
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-23-2017, 01:59 PM   #30
Willie Makeit
Willie Makeit's Avatar
Willie,
Brandon
Fabricated parts are top notch! Just wish some of the other was a bit better.
You guys will definitely have another opportunity based on the responsiveness in this conversation thread and the quality of the parts.
Parts are installed and truck is back on the road. It's all good!
Willie Makeit is offline   Reply With Quote
Old 06-25-2017, 11:37 AM   #31
SierraMtns
SierraMtns's Avatar
This was within the past 2-3 weeks. I didn't get return calls for the previous messages left and I didn't have another 8 weeks to wait on another set of lower arms so I repaired them myself.
I don't see it as bashing, only sharing my experience.
Lets see some pictures of the truck.....
SierraMtns is offline   Reply With Quote
Old 06-25-2017, 11:39 AM   #32
SierraMtns
SierraMtns's Avatar
Did you get your kit yet? If you email me your order #, I'll give you an update on build time.
Brandon
Not yet. I placed my order on 6/15. So I am still in the back of the line...ha ha
Old 06-25-2017, 11:53 AM   #33
SierraMtns
SierraMtns's Avatar
Brandon
Yes I was.
Went with Stage 2 Deluxe kit with 1" narrow and 1" forward arms.
3" CPP drop strings
CPP 5x5 lug drop spindle kit with brakes
Ridetech HQ shock
Total $2,495
I did have to give up on Rack-n-pinion steering and run old school power steering. I might down grade the Ridetech HQ shocks and save a couple bucks.
I placed the order on the kit now to get in line ASAP and will order the rest of the parts once the kit is complete.
Old 06-26-2017, 11:46 AM   #34
68is4me
68is4me's Avatar
Keep the HQ's you wont be disappointed. I actually wanted to run the RQ's, (didn't really need the adjustability), but ridetech no longer makes them. For the 2 miles of in town driving I have done with the HQ's I have been impressed.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 06-27-2017, 10:44 AM   #35
SierraMtns
SierraMtns's Avatar
Anyone have pictures with this setup in the front?
I am planing on running 18's
Old 07-02-2017, 12:32 PM   #36
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like photobucket strikes again with no pictures.
This is really going to affect a lot of threads on this board,...
Keith
Convert to disc brakes.
Old 07-03-2017, 01:13 AM   #37
SierraMtns
SierraMtns's Avatar
Yeah they have been a problem lately.
Do you recommend another company?
Old 07-03-2017, 11:10 AM   #38
lolife99
lolife99's Avatar
I load photos from my iphone or iPad directly.
I don't host them anywhere.
You can also load them into the photo gallery here on this board.
Keith
Old 07-05-2017, 08:16 PM   #39
gringoloco
A guy with a truck
gringoloco's Avatar
Yup, then they're here for future reference. Glad I saved my important reference pics
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-19-2017, 01:04 AM   #40
SierraMtns
SierraMtns's Avatar
Just got word from PB Fab. The kit is almost done and should ship this week.
Old 07-24-2017, 04:47 AM   #41
Klmor
I ordered a few days after you and I still have two weeks to go. My new shop is behind schedule so I'm not in a big rush. I can say I'm not use to waiting this long for parts, but it's giving me time to do other things. The last time I was in a rush to get things Chris had to help me install it all months later.
Klmor is offline   Reply With Quote
