#176 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: What did you do to your truck today part IV
forestb if you can get away with it I think it's awesome.
#177 |
I also was able to drive the truck for the first time on the freeway with the new 700r4. Vary happy 😊
Posted via Mobile Device |
#178 |
Finally got the engine back together with the new camshaft kit from CompCams. Nothing wild, just a replacement for the worn out one that left me stranded last month.
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
#179 |
http://67-72chevytrucks.com/vboard/s...4&postcount=90
^installed new cam kit SHE'S ALIVE!!! https://youtu.be/26ZDzVYPUbw After realizing i put the dizzy in backwards again, did the same thing for the first engine start up, she fired right up. We ran her through the COMPCams break-in procedure with only one hiccup. I hadn't fully tightened the distributor after spinning it around and it walked the timing way back to where it was backfiring real bad. I tighten it back down in the right spot and ran her 25 min between 2000-3000rpm, varying ever few minutes.
#180 |
Installed the Sissy Box under the dash.......
http://s1299.photobucket.com/user/jb...23904108567829 |
#181 |
![]() Join Date: Jun 2015
Ooh! I want me one of those! Did I mention, I am female
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
#182 |
This is a quick search on eBay, where I found mind. if you have a Chevy, they have them with the proper badges, but nothing technical correct for GMC, so I found a generic one with no badging. The make a few styles, you need to look for a "swing out" type, they make a pull out type but it would mount to the underside of our dashes.
http://www.ebay.com/itm/VINTAGE-ORIG...VZKkNb&vxp=mtr http://www.ebay.com/itm/Vintage-Klee...FY2s-n&vxp=mtr https://www.ebay.com/sch/i.html?_odk...enser&_sacat=0 Use this search string terms "vintage 195* tissue dispenser"
#183 |
![]() Join Date: Sep 2016
Got the engine in last night.
#184 |
Installed a cup holder.
#185 |
lacquer the wood boards
#186 | |
![]() Join Date: Jan 2012
I got my wood from Mar-K and it's Pecan. It takes forever though, staining it with the spar... thinning down the first few coats and then putting pull strength coats on, each side. It's been taking at least 12 hours for each coat to dry (the thinned coats are drying faster, of course). |
#187 |
![]() Join Date: Nov 2015
I replaced the rockers on my pickup. They turned out good, but I'm glad I don't have to do that again!
#188 |
Replaced the master cylinder after 2 years of pumping brakes.
Flushed and bleed them 2 days ago with fresh BF and then replaced MC this morning. Stops awesome now! |
#189 |
replaced the mechanical fuel pump with an electronic one....because I thought I needed a new fuel pump. Turns out, I was just out of gas. Didnt realize how much gas would evaporate from not driving it for 2 months.
#190 |
![]() Join Date: Jan 2017
thats funny!!! glad I am not the only one
#191 |
Installed the aluminum radiator.
#192 |
I picked up my vent windows and a side window.I will test fit them and se how it goes.
#193 |
I patched up the extra holes in my high and installed it. Used rivnuts to so it can be removed as needed.
#194 |
I replace my wiper blaids with a set of 12" Champion blades. I hade to buy a hole assembly and take it apart to use only the rubber. I hade to do a little cutting to make them slide in but they look like they will work well.
I also used a d-ring to lock my column shirt linkage in park (as a society measure). With the hood locked you can't take the truck out of park. I am also trying to figure out a way to lock my steering column inside the engine compartment. Posted via Mobile Device |
#195 |
I was told to drill a hole in the shaft than put a bar in it.When you turn it it will hit the inter fender.
#196 |
I put the wood in my bed.
#197 |
#198 |
#199 |
Ha! I think rvrfoot and I are on the same schedule.
I just got my wood installed this week/weekend myself. Last edited by AngryPirate; 07-16-2017 at 10:15 PM. |
#200 |
I got a new back window had it tinted.Installed it and new seal.
