Old 06-26-2017, 09:26 PM   #1
tim71
tim71's Avatar
Radiator Fan Shroud
I'm in the process of putting my truck back together from a total tear down. Almost ready to put the front core support back in place. Today I gave the radiator fan shroud a good bath and scrubbing. Shroud is in good shape and cleaned up pretty well but doesn't look very good contrasting against all the fresh paint around it. Is there a way or method to make these shrouds look better?
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 06-26-2017, 09:44 PM   #2
Duck 37
Smile Re: Radiator Fan Shroud
SEM trim black worked for me.
Duck 37 is offline   Reply With Quote
Old 06-26-2017, 09:53 PM   #3
Grumpy old man
Grumpy old man's Avatar
Use a scotch brite pad and really clean the surface you can use dawn soap/water to help the process ,then wipe it down with 3M prep solvent 70 or just lacquer thinner ,then use a couple light coats of Matte clear , This really works good on the A/C - heater box also . Matte clear must be sprayed in very light coats with ample dry time between coats . It works for me .
Old 06-26-2017, 10:57 PM   #4
FirstOwner69
FirstOwner69's Avatar
I wouldn't paint it if you want it to appear original and like new. I may be criticized for this, but, if you've cleaned it thoroughly without using abrasives and it isn't covered with scratches, try applying a protectant such as ArmorAll or Son Of A Gun then wipe it off almost immediately. Personally, I prefer Son Of A Gun. The shroud will stay looking good (and original) a long, long time. I also used it on the evaporator box and it looks new.
FirstOwner69 is offline   Reply With Quote
