Old 07-02-2017, 09:52 PM   #1
rockyrivermark
Clear over polished grille
Subject been discussed here before using auto clear coats etc with conflicting results.
I'm looking to clear over my polished grille since it always needs polishing. I tried wax over it but doesn't help much
I researched a bit and found a commercial coat especially made for various metals including aluminum.
Used on exterior building and storefront doors etc.
anybody try it? If not I'm game and will post my results.
https://www.everbritecoatings.com/ca...-only-c-7.html
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-03-2017, 10:10 AM   #2
CG
BlahBlahBlah
Re: Clear over polished grille
Wonder if having it clear powder coated would work?
Old 07-03-2017, 11:25 AM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-03-2017, 11:32 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subbed for future info
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-03-2017, 12:35 PM   #5
beadblaster
beadblaster's Avatar
I have used the everbrite on polished rims and various polished parts. Works as described,just make sure you clean the metal with wax and grease remover prior to applying. I have used a spray gun as well as foam brushes to apply and you cannot tell one from the other once dry.
beadblaster is offline   Reply With Quote
Old 07-03-2017, 12:45 PM   #6
HeavyD
HeavyD's Avatar
How long is the coating expected to last?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 07-03-2017, 01:19 PM   #7
rockyrivermark
They also sell it in rattle can.
Not sure how long it lasts. I think a long time being a coating used on high traffic areas such as commercial doors. . Check out the website. I'll try it and post my results
Old 07-05-2017, 11:10 PM   #8
rockyrivermark
I tried the perma clear today. Tired of constantly polishing the inprotected aluminum, constant battle.
First was to polish with Mothers mag and aluminum polish and microfiber buff by hands . Absolutely amazing stuff by the way.
Then directions for permaclear say to wipe metal with baking soda and water to mutrelize any acid from the polish
Then wipe down with denature alcohol or xylene
Use denatured alcohol! Xylene is nasty stuff. Very high VOC
I bought 4oz bottle and applied with foam brush.
Laid down like a spray finish. Pretty thin stuff.
Anyway. Looks great and I'll post in a month to see how sits holding up.
I think we have something here though
See pics.
Mark.
My build page
Old 07-05-2017, 11:31 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Subscribed
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-06-2017, 01:25 AM   #10
ApacheIvan
ApacheIvan's Avatar
Subscribed!
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-06-2017, 02:15 AM   #11
70 cst
70 cst's Avatar
Subscribed
70 cst is offline   Reply With Quote
Old 07-06-2017, 09:08 AM   #12
Shinysideup
Shinysideup's Avatar
I read their info and no mention of UV resistance? They also state easy to strip and redo, how is that accomplished? Did you choose the brush because you applied it already mounted to truck vs the spray?
It looks like the original anodizing with a thin satin finish,is that right?
Thanks for the info.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 07-06-2017, 09:47 AM   #13
rockyrivermark
Yes I used the foam brush rather than remove or mask off entire grille
The permaclear gave the finish a bit more gloss finish.
I have to check it this morning now that it's dry.
Not sure on the UV protection. I would email them for more info.
All I know was for $20 on amazon it was worth a shot.
https://www.everbritecoatings.com/ca...ar-ezp-97.html
My build page
Old 07-06-2017, 08:39 PM   #14
custom10nut
custom10nut's Avatar
Subscribed
custom10nut is online now   Reply With Quote
Old 07-06-2017, 10:16 PM   #15
rockyrivermark
I checked this morning. The finish looks good. No brush marks although I used a foam brush, either way the stuff laid down nice.
Looks factory and see what time does.
I got the 4oz can and and used very little of it so it goes a long way.
RRM
My build page
Old 07-06-2017, 11:37 PM   #16
ls1nova71
ls1nova71's Avatar
Sub'd for results in a month.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-07-2017, 05:56 PM   #17
CG
BlahBlahBlah
Looks good! I just looked at my dopey earlier comment. Read right past what you were up to and assumed you were looking for ideas ... duh haha.
Old 07-07-2017, 09:32 PM   #18
Ol Blue K20
Looks great, I hope it lasts. Waiting for your conclusion on that.
Dale
Old 07-07-2017, 09:42 PM   #19
rockyrivermark
I'll keep you posted.
Old 07-07-2017, 09:51 PM   #20
Classic v6 GMC's
Classic v6 GMC's's Avatar
following
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 07-08-2017, 12:12 AM   #21
k29349
I have had Everbrite on some E-T slot mags for 3 years now. They still look great and they get driven a lot.
k29349 is offline   Reply With Quote
Old 07-08-2017, 08:25 AM   #22
67swb72klb
67swb72klb's Avatar
I think you nailed it looks like an OE finish hope it holds up...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-08-2017, 09:51 AM   #23
Tdrcreyn4
Tdrcreyn4's Avatar
sub
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 08-08-2017, 10:04 PM   #24
rockyrivermark
Originally Posted by Tdrcreyn4 View Post
sub
Well I promised I would post one month results.
So far the coating is working great. Looks exactly has it did when I applied it.
Previously for this I was trying wax and other products and having to re polish weekly to get the grill looking nice.
Anyway. Highly recommend
Pic attached.
Old 08-09-2017, 08:23 AM   #25
Keith Seymore
Keith Seymore's Avatar
Relative to my current project at GM: we are using CNC billet polished aluminum for the bright exterior trim (body side moldings, window trim, etc).
We used clear powdercoat over the aluminum (which is the production process for aluminum wheels) but are gravitating towards using automotive clear paint over the aluminum, which gives us a little bit smoother finish.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
