Old 07-05-2017, 03:59 PM   #1
johnsonzach47
Unhappy 5.3 swap 1980 k10 HELPPPP!
hey guys new to the forum need some help figuring out a fuel system for my 5.3 swap i just dont know where to begin
johnsonzach47 is offline   Reply With Quote
Old 07-05-2017, 05:17 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 5.3 swap 1980 k10 HELPPPP!
On mine I used a walbro inline 255 pump and a vette filter/regulator...the regulator bypasses back into the tank..on the engine fuel rails there was a return rail..I capped that off with -an fittings..the pump is run by a relay in the fuse block that came with my psi harness....this is just one way to do it..there are others...I plumbed all my fuel lines with -6 an hoses and fittings...
Old 07-05-2017, 07:46 PM   #3
johnsonzach47
Did you have to get a new tank to adapt to that?
Old 07-05-2017, 08:30 PM   #4
Dads79GMC
Dads79GMC's Avatar
I followed much of what "soule64" did in his build thread called: "Another LSx/4L60e Swap"
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=381669
Entry #11
Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 07-05-2017, 08:40 PM   #5
Dads79GMC
Dads79GMC's Avatar
External pump I've heard makes way too much noise from what I've been told????
Old 07-05-2017, 09:01 PM   #6
mongocanfly
Zach..No new tank...but my original tank had a return port on it already..on my sending unit i have a suction, a return, and a vent barb on it..if your doesn't have that you would need to ad one if done like my setup.. you can always do an intank pump but that's extra work I didn't want to do...external pump works great..
Dads79...I'm sure not all pumps are created equal but the only time you can hear mine is when you turn on the switch before cranking...you can sorta hear it if you get your ear down close to the tank..half my tank is under drivers seat..other half under the bed..pump, filter, regulator sits on top of the tank
Old 07-05-2017, 09:04 PM   #7
Dads79GMC
Dads79GMC's Avatar
Old 07-05-2017, 09:06 PM   #8
johnsonzach47
Thanks guys i appreciate it!
Old 07-07-2017, 05:39 PM   #9
bigblazerboy
bigblazerboy's Avatar
i used the tank from a 87 tbi truck with a bigger pump in the sender ment for a ls truck. an fittings and lines to the rail. mine has regulator on rail and return style so nothing extra but what i mentioned had to be done besides wires to the fuel pump as well
1995 tahoe lt 4x4
http://www.cardomain.com/ride/3856942
bigblazerboy is offline   Reply With Quote
Old 07-07-2017, 06:14 PM   #10
86c10shorty
boydwelding.com has perfect fuel tank setup for that.
86c10shorty is offline   Reply With Quote
Old 07-07-2017, 07:02 PM   #11
ivorton74
ivorton74's Avatar
On my old 74 i had the stock tank with an inline walbro 255 pump and a fuel filter before the pump. Used regular rubber fuel lines
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 07-07-2017, 09:47 PM   #12
mongocanfly
Ivorton...i wouldn't be using reg rubber gas line on a high pressure fuel system
Old 07-07-2017, 10:58 PM   #13
ivorton74
ivorton74's Avatar
It actually wasnt rubber...it remember it was some kinda high pressure line tho...cant remember what its made of. But anyways never had any troubles with it at all...no leaks or anything
Old 07-07-2017, 11:38 PM   #14
mongocanfly
The factory lines are a hard plastic..
5.3, k10, ls swap
