How do you attach upper trim?
How do you attach the upper trim on a short bed? I haven't started it yet but I don't see how you can get the nuts on the back of the trim clips. No access and the bed has never ben drilled for the. Thanks Bill
Re: How do you attach upper trim?
I believe 69 & 70 used spring-metal snap-in clips to attach the upper bedside molding.
Sometime around 71 or so they changed to plastic clips stuck to the body with 3M (or similar) adhesive. I think they still used the snap-in metal clips at the very front & back ends of the molding though. |
Thanks I did order my new molding and it comes with 3m adhesive strips. I guess I will wait until get them to check it out.
Thanks Bill |
#4 | |
Typical of everything I bought from LMC. garbage. If it's not 3m VHB tape change it over before sticking. Posted via Mobile Device |
I'll have to check I think I got them from Brothers or Classic.
Thanks Bill |
Oh I was wrong I did order them from LMC. I got doors from Goodmark and some other things from Classic.
How are they other than the adhesive? I can put 3M double side tape on them. |
![]() Join Date: Aug 2013
Here you go
These are the clips and stickers From left to right Lmc clip Classic or maybe brothers clip Lmc adhesive Broken original clip I never use the adehesive It doesn't stick good and it holds the trim to far from body Originally Long beds had 4clips. 2 front 2 rear and 10 or 12 stickers Short beds had 1 clip front and back and 8 stickers Anytime I'm putting upper trim on I string line between front and back hole And drill 6 to 8 more holes matching original size Equidistant between originals And use ALL clips(just order more) This guarantee's your trim will stay on Even on original trucks where the stickers have failed Usually the clips are still holding strong Red truck is shortbed,first pic still shows broken original clip in hole Ochre truck is longbed |
#8 | |
Cut off the old tape and used a quality 3m tape. So far no problems. Clean bed of all wax along trim line first. The trim itself is decent. FYI for others. The lower body trim was LMC was a pain. The clips where too short and would spin when tightening the nut. The clip is supposed to be a bit longer so it cannot spin but rather lock in. I retuned most of the items I got from LMC. it's just crap. RRM
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Thanks for the info I may buy new clips. I think I got it now most of the clips on the bed just push into place. The end ones have nuts.
They all push in....
#12 | |
#13 | |
Whatever works I think most all sell individually Try and get the black ones. I like those better than lmc ones |
![]() Join Date: Feb 2009
For what it's worth, see post #1 at the following link. It lists what came with my NOS upper, lower & rears moldings. Includes some other info. that may make life easier.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=735842
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#15 |
Pics for randy500
These are measurements of the stock holes Front and back upper trim On a Shortbed In the first pic the lower tape measure IS lined up with body crease (Even though it doesn't look like it) In the last pic. The tape measure is hooked on the curve of the metal Inside cavity for marker. NOT where metal ends |
