07-14-2017, 07:01 PM | #1 |
Questions on LS motor
Thanks in advance for your replies .
I am going to a junkyard and look at an LS in a 2002 chevy truck 4x4 with 130000 on a 5.3 to listen and hear it run next week . If I decide to purchase I must pull the motor myself but I have know idea of what all I need ?? I know the EMC and the harness . Gas pedal?? Or any other misc pieces and parts . Oh pics would be nice too. |
07-14-2017, 07:27 PM | #2 |
Moderator
Re: Questions on LS motor
Radiator, all engine accessories and wiring, exhaust manifolds and pipes and cats, all ecm and wiring looms, gas pedal.
What trans do you intend to use? Try and find a 2WD 4 spped e trans and controller and wiring loom... You will need aftermarket engine mounts and mounting supports, rear cross member...drive shaft.... Always best to try and find a full donor vehicle and sell unused parts after you are done... |
07-14-2017, 09:51 PM | #3 | |
07-14-2017, 10:22 PM | #4 |
The Older Generation
There is an LS Swaps forum on here that has all of the info you need. http://67-72chevytrucks.com/vboard/f...prune=-1&f=206 LockDoc
07-15-2017, 07:24 AM | #5 |
I can't remember if the 5.3l switched to electronic throttle by 2002 or if it was still drive by cable. If it does have electronic throttle, you will need the gas pedal and tac module as well.
07-15-2017, 07:55 AM | #6 |
Make sure to listen to the engine after a cold start. If you go to see/listen to it and it's warm at all leave and come back another morning to make sure you get a true cold start. You can listen for excessive noise and wear issues; check for cold start low oil pressure warnings on the dash and the notorious sticky lifter ticks. LS engines are known for oil pump pick up "O" ring failures causing low oil pressure at start up and lifter ticks esp after ideling for 10-15 minutes at low RPMs.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
07-15-2017, 10:08 AM | #7 |
There are aftermarket intake kits with minimal wiring required to run the coil packs. It just depends on what you're looking to do. Full fuel injection will require a lot more than if you go carbureted.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
07-16-2017, 04:52 PM | #8 |
If it's included in price, grab everything you can. Pedal, TAC, ecu, all wiring including power and grounds from battery.
07-16-2017, 10:17 PM | #9 | |
Active Member
