Old 07-17-2017, 10:53 PM   #1
dcfd470
Fuel Pump
I relocated my gas tank to the rear of my 1972 and my question is what fuel pump should I use? I have quadrajet carb with a 350 engine that has the engine mounted mechanical fuel pump on it. Do I delete the mechanical one and add the electric fuel pump? Here is the one that I saw today but I did not know if it would work or not.
dcfd470 is offline   Reply With Quote
Old 07-17-2017, 10:55 PM   #2
truckster
truckster's Avatar
Re: Fuel Pump
The Blazers and Suburbans use a mechanical pump to pull fuel from the rear. I don't see any reason you need to change yours if it's working.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-17-2017, 11:00 PM   #3
dcfd470
Re: Fuel Pump
It was working fine when the tank was behind the seat. I just figured that it being farther away it may need a boost? If the mechanical one will work I will keep it that way. Thanks for the reply.
Old 07-17-2017, 11:36 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Fuel Pump
I used a Holley Red electric fuel pump on my '67 K/10 Suburban w/454. It worked real good, until a carb fire started in the engine bay. I did not think the Holley recommended oil pressure threshold cut-off switch was necessary. I was wrong. The electric pump still kept pumping, making things worse. Some guys with fire extinguishers helped knock it out. My other mistake was reporting it as a claim on my insurance. They ''totalled'' the truck. I got peanuts and Suburban with a salvage title.
Old 07-18-2017, 05:35 PM   #5
Eddie H.
Eddie H.'s Avatar
Re: Fuel Pump
Your mechanical pump will work fine as it is. No need to do anything at all.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-18-2017, 06:25 PM   #6
dcfd470
Re: Fuel Pump
Thanks for the responses I am keeping the mechanical pump.
