Old 07-20-2017, 12:46 AM   #1
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Need help (pics) Identifying parts
Can anyone help me identify these parts? The plastic piece inside the cowl and whatever is coming out from it. close up pics of inside the cowl would be super helpful. Thanks
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 07-20-2017, 01:11 AM   #2
72K5CSTDarkOlive
Re: Need help (pics) Identifying parts
I submitted this in my build thread but hoping to find help asap.
The Factory Assembly Manual refers to the L Shape tube as a "shaft" (#21) in the diagram. I found the metal piece ( also referred to as crank from others on here) that slides into the shaft and attached via a screw. (#3) "Cap" and (#4) "Bearing" stated in the diagram is where I am lost.
The Spring (#2) Looks like it attaches to the top side of the cowl and the other end connects to something, I have no idea what, shown here in the diagram (#1) Valve ASM at the bottom right corner.
What does this "Cap" (#3) look like? Is it available? Are there alternative options?
What about the "Bearing" (#4) Is it available? Are there alternative options?
Appreciate any help from the board. Thanks!
Old 07-20-2017, 07:31 AM   #3
1rippen6
I have a few pictures I can post tonight. Not the greatest should have taken better ones. I should have everything you need if you don't have it.
1rippen6 is offline   Reply With Quote
Old 07-20-2017, 08:44 AM   #4
1972 Jimmy
1972 Jimmy's Avatar
I also can take some pics for you tonight. I'm currently putting my A/C back together as well.
Eric
1972 Jimmy is offline   Reply With Quote
Old 07-20-2017, 09:35 AM   #5
72K5CSTDarkOlive
Eric
Yes, Please!! the more the better.
@1rippen - I'm not entirely sure which pieces I need. I know I don't have the ones I mentioned above, (Cap, Bearing, Spring) but there could be other parts, but without knowing what I'm looking at I don't know.
And whatever goes in those two holes in the cowl (Dash side) pictured above. I'll need these too.
Thanks guys
Old 07-20-2017, 10:02 AM   #6
1rippen6
http://67-72chevytrucks.com/vboard/s...=505987&page=9
Check out post 212
Old 07-20-2017, 02:23 PM   #7
72K5CSTDarkOlive
I'm missing all of this. Do you have any of these parts?
Old 07-20-2017, 02:34 PM   #8
1rippen6
Yep, should have everything off that rough jimmy I just scrapped.
Old 07-20-2017, 03:23 PM   #9
72K5CSTDarkOlive
PM Sent
