Old 07-21-2017, 06:07 AM   #1
bgray
Flip kit for 76 2wd k5
Hey everyone. Lowered k5 info seems to be a bit harder to find.
I halve a belltech flip kit on the way for my 76 k5 2wd, but I wanna clarify how to achieve a 6" drop. I ordered a 1.75" lift shackle cause I believe the 6" flip actually drops 8" for blazers correct?
People talk about having springs rear arched or different springs all together?
bgray is offline   Reply With Quote
Old 07-21-2017, 06:09 AM   #2
bgray
Old 07-21-2017, 07:53 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Flip kit for 76 2wd k5
Yes a flip kit on a blazer, lowers the rear more than on a pickup.
This is kind of a true statement.
I think it just puts the rear axle closer to the frame rails, because the blazer frame is different than the trucks.
It will also put the center section of the rearend really close to the floor.
There are companies now making blazer c-notches.
I recommend this.
http://www.crownsuspension.com/lower...r-c-notch-kit/
A lift shackle would probably work.
I'd like to see the one you bought.
Another option is to run a 4x4 rear spring hanger with your flip kit.
(they are longer than the 2wd version)
But these would have to be found used at a junk yard.
And they are riveted on just like the trucks leaf spring hangers.
Keith
Convert to disc brakes.
Old 07-21-2017, 08:31 AM   #4
bgray
Thanks for the info. Im going to install, and just see where i sit after i suppose
Old 07-21-2017, 02:31 PM   #5
phillipm
Had a standard flip on my blazer. Sat too low and hit the frame on every bump just about. Installed a c notch but also ended up having my leafs re-arched 1". So total drop in the rear was 5" after that.
Old 07-21-2017, 06:05 PM   #6
Willowrun
Willowrun's Avatar
Nice Blazer.
I did a flip combined with 4x4 rear hangers and a 1/2" lowering block. The flip by itself was too low.
Old 07-22-2017, 08:14 AM   #7
bgray
Just gonna install it and see where i sit. After i get the ride height how i want it, were gonna burn in a custom notch
Old 09-23-2017, 09:37 AM   #8
wishmasstir
Originally Posted by Willowrun View Post
Nice Blazer.
I thought a block after an axle flip will lower the rear end more? or was it needed because the 4x4 rear hangers raised it up too much?
wishmasstir is offline   Reply With Quote
Old 09-23-2017, 10:47 AM   #9
Willowrun
Willowrun's Avatar
Correct. The 4x4 rear hangers were installed to lessen the amount of lowering from the axle flip alone. After doing the entire hanger swap and flip I felt there was too much of a nose down rake so I added the small blocks to lower the rear (essentially raising the axle) 1/2".
Old 09-24-2017, 03:26 PM   #10
wishmasstir
Do you have a part number for the hangers you used?
Old 09-24-2017, 06:50 PM   #11
Willowrun
Willowrun's Avatar
I don't, sorry. They are just 4x4 rear spring hangers for 73-87 K5 or K10.
Here is a thread where I show what I did in the rear of the Jimmy above. Starts on page 2.
http://67-72chevytrucks.com/vboard/s...d.php?t=645053
Old 09-24-2017, 06:55 PM   #12
Willowrun
Willowrun's Avatar
Here a pic I took after putting factory block back in.
Old 09-24-2017, 06:56 PM   #13
Willowrun
Willowrun's Avatar
4x4 hanger
Old 09-28-2017, 05:01 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
What size wheels are you running? Staggered? Backspacing? What size and brand of tires?
Any outside side shots?
Rich
1972 K5 Blazer CST Click HERE
