Old 07-21-2017, 10:36 AM   #1
gramps77
EFI fuel supply opinions
My long bed 77 has the stock dual tanks that work and feed well with the carb setup. I just purchased the MSD Atomic EFI to be CARB compliant here in California. I have their fuel pump kit that goes with it. I also currently have the Pollack 42-308p six port dual tank transfer kit to swap if I go that route rated for EFI PRESSURE. I'm worried about fuel starvation and weighing other options. Ideally, what would you do? The truck currently has 16 gallon tanks so I'm considering a swap to 87 20 gallon tanks. As well as a FITech or Edelbrock fuel sump kit if I keep the stock plumbing.
gramps77 is offline   Reply With Quote
Old 07-21-2017, 12:58 PM   #2
donw1986
Re: EFI fuel supply opinions
I am in the process of installing the MSD kit on my 86 Chevy C10 I went with the MSD pump and bought a second one and install them in 1987 tanks I also live in California I just installed the first tank yesterday so I haven't tried them out yet
donw1986 is offline   Reply With Quote
Old 07-21-2017, 10:04 PM   #3
funkatation
In tank pump is the way to go
funkatation is offline   Reply With Quote
Old 07-21-2017, 10:53 PM   #4
gramps77
What do you mean installed the MSD pumps in the tank? What float and pickup did you use at the tank neck?
Old 07-21-2017, 10:54 PM   #5
gramps77
Which in tank pump? I looked up the 87 pump and pickup and I didn't think it had enough pressure
Old 07-21-2017, 11:01 PM   #6
donw1986
I mounted the msd pumps on 87 sending units, havent tried it yet but should work the 87 sending units have a mount for the stock pump the i mounted a strainer/sock over the inlet
Old 07-22-2017, 11:50 AM   #7
donw1986
Had to remove about 3/4 inch off of sending unit tube for outlet fitting to fit, and removed inlet fitting for sock,filter, then plumbed it to selector valve for dual tank operation and need to change selector switch to an 87 switch to provide power to pumps
Old 07-22-2017, 01:02 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
What MSD kit is this that is CARB approved
Malo83 is offline   Reply With Quote
Old 07-22-2017, 01:18 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
Found it.
Old 07-22-2017, 01:49 PM   #10
donw1986
Msd atomic efi
