#5601 |
![]() Join Date: Aug 2015
Re: What did you do to your truck today? Chapter II
I passed a New Hampshire state inspection today. The truck had a valid NH inspection sticker on it when I bought it last year, but it should not have had one for several reasons.
First issue was a total failed rag joint, made worse by the fact that the coupler was separated enough that it was close to zero steering control. That was the first repair I did a couple of days after I bought it. Second was that someone had used lift blocks to raise the front end. I installed new front springs last week. Third was a decent sized hole in the drivers side floor, which I patched last week. The tech did a thorough job and I am happy to be on the road again! Last edited by ohboy321; 07-21-2017 at 08:32 PM. Reason: spelling |
#5602 |
no inspection in NJ
#5603 |
Installed sway bar , buttoned up power steering . Lots of parts waiting inc freshly upholstered buddy seat & carpet kit . just waiting on body man .
#5604 |
I installed a new water pump and did a full trans flush great day
#5605 |
Where's my beer?
Went outside at 7am today, and worked steady until 7pm doing a driveway paint job on mine. The weatherman saying heat advisory can suck it! Now, to figure out the new way to post pics since photobucket is a no go anymore.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#5606 |
![]() Join Date: Jul 2015
You do not need Photo F%$!it. Load pics from camera phone to computer. And away their scheme went!
#5607 |
Moderator
![]() Join Date: Jun 2017
PB and other originally "free" photo sharing services are really un-necessary and all rely on their user base just accepting their new fees to share what is essentially not even their property...your images.
Most phones nowadays will allow the pics stored on the phone to be downloaded to a computer...usually using the charger cord that has a USB style connection on the power pack end. For those unaware of how to do the transfer, on a Windows computer, On your desktop, right click and choose New Folder...name the folder "pics"... Now connect your phone to the computer by plugging the power pack end of the charger cord into a USB port on the computer. You will see two messages pop up...one on the phone asking permission to connect to the computer...just press connect or permit...and a message on the computer in a menu popup choose "open folder to view files"... On the computer, navigate down to the images on the phone...hold down the Shift key and choose the images you want to copy from the phone to your computer,,,right click, choose Copy.... On the computer, open the "pics" folder, right click and choose Paste...the images will load to the pics folder. Depending on your phone camera settings, the images may be too large for the site to accept...You can use the Windows included program Paint to resize your images, albeit, you need to do them one at a time. Choose an image, right click, choose Open With, then choose Paint, choose Resize, then type in 3) and leave it as %...the image will downsize to 30 % of its original size...choose Save, then close Paint... Do this for each image you need to resize. To upload an image when making a post, go to Attachments option...choose the image and choose Upload... Hope this helps out some folks... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#5608 |
![]() Join Date: Feb 2009
Cleaned the paint off the fuel and vent lines, from a two-bit frame restoration I did some decades ago.
An initial polish as well. The picture is bad, but I've since stored them away. They're like new. While I wouldn't have thought it's relevant, I've seen the lines on my other truck, yikes.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-23-2017 at 07:33 PM. |
#5609 |
All SS brake lines in all 4 corners are finally plumbed in... what a PITA that was. Now on to the SS fuel line. Stained the bed floor with the black and next time Im home Ill sand it back down so the black is only in the grain and then Ill re-stain in a more natural color and clear coat... going for an aged look... not sure why some of the boards came out kind of smoky and some are lighter than others when I did the same thing to all of them, but it shouldn't make a difference once its all sanded bake down... This hydraulic flaring tool is awesome!
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#5610 |
Looking good .
#5611 |
#5612 |
![]() Join Date: Jul 2016
PB has really put us in a temporary squeeze. I've stopped uploading photos there. I've begun to use Flickr again. Trying to attach pictures to a post is more inconvenient in my opinion. And some forums limit each post to only 1 attachment.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#5613 |
BIG PROGRESS TODAY at least for me.....
Had to go get a friend so he could help me (his truck doesn't run) but once back we were able to get the headlights back on along with the fan shroud, hood latch, and hood latch support bracket. I spray painted my old bolt j-nuts with Eastwood Chassis Paint. Hope to get the grill on tomorrow! |
#5614 |
A friend helped me get the headlights back on along with the fan shroud, hood latch, and hood latch support bracket. I spray painted my old bolt j-nuts for the hood latch support bracket with Eastwood Chassis Paint. Hope to get the grill on tomorrow! |
#5615 |
![]() Join Date: Jun 2005
On Sunday, went and picked up a new SB fleet bed and met a member of the board. Now the real fun begins - removal of old bed and installation of new one.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#5616 |
Need pictures or it didn'thappen....
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5617 |
![]() Join Date: Nov 2004
I told her she looked pretty (I lied.)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#5618 |
Rut roh !
Stan 67 swb BLU MULE posted via flip-fone |
#5619 |
Sides and floor still in boxes, but will post pics when I get the trailer unloaded.
#5620 |
Thank you Sir ! .
Pix of pieces would be O.K. too .
#5621 |
Will take more pics when I get them out of the boxes
#5622 |
New ball joints,tie rod ends, center link,u joints, steering sector
Brake controller. I had some good help |
#5623 |
Free help in training, can't beat that.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#5624 |
Nice truck ~ K20, correct ? .
#5625 |
Looks like a K10, Nate.
