Old 07-21-2017, 09:16 PM   #1
hdixon
Serpentine Belt
Has anyone use and after market serpentine belt kit on there C10 is so what kind how you like it any picture out there
hdixon is offline   Reply With Quote
Old 07-21-2017, 09:48 PM   #2
harpo231
harpo231's Avatar
Re: Serpentine Belt
GM sells them without the bling , best buy id say, if goin new
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-21-2017, 10:47 PM   #3
Rufas
Rufas's Avatar
Re: Serpentine Belt
I bought this March setup about 15 years ago. Just got the engine started for the for fist time last fall. There seems to be some minor vibrations issues. Nothing that can't be fixed. Just waiting to get the truck back from painting so I can work on it.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 07-21-2017, 10:53 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Serpentine Belt
Here is my GM set up with part numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=468729
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-22-2017, 08:44 AM   #5
Shinysideup
Shinysideup's Avatar
Re: Serpentine Belt
Pull a complete setup from a wrecking yard for less than $100. Looks and works great.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 07-22-2017, 12:28 PM   #6
deereguy7460
deereguy7460's Avatar
Re: Serpentine Belt
The serpentine belt setups from 89-95 5.7, 5.0 and 4.3 will work just fine and are readily available and local salvage yards. Make sure to get a reverse flow fan and water pump because the factory belt will spin the water pump pulley backward from what your truck was. Don't forget the pulley for the dampener and power steering pump while you are searching. Higher output alternator was nice to add while I did mine. Pictures were from before I did the 5.3 4l60e swap. I was very amazed how much different the engine sounded after the upgrade.
'70 C10 Short Wide 5.3 4L60E 2wd 3.73 W/Locker
'69 C10 Short Narrow 5.3 4L60E 4x4 3.73 on 01 Tahoe Frame - work in process
deereguy7460 is offline   Reply With Quote
