07-24-2017, 12:23 PM | #1 |
Throttle cable binding, suggestions?
Hi all,
Finally got my '68 k10 big block project on the road and now I'm trying to work the bugs out of it. One of the issues is that the throttle cable has a pretty severe bend in it making the gas pedal stiff and low speed maneuvering difficult. Here is my current set up: Lokar pedal assembly, cheap off brand throttle cable, and an Edelbrock intake manifold, carb, and throttle bracket on top of a 454. I have a few ideas in mind, but I'd like to hear what you guys think. I'm sick of accidentally chirping the tires at every intersection! Posted via Mobile Device |
07-24-2017, 01:53 PM | #2 |
Re: Throttle cable binding, suggestions?
I don't see that pedal on the lokar site. Maybe it was disco'd for a reason?
I would think there would be more cable sticking out of the housing inside of the vehicle. Looks like at closed throttle, the cable end is hitting the cable housing mounting. But you can't add cable... Lube the crap out of it? Find a better cable that has a sleeve? Maybe change the position of the pedal so you have more working leverage - I think you can index the lever and pedal differently right? Add a stiffer return spring if its hanging the throttle open?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-24-2017, 03:59 PM | #3 |
Might be your cable is it sleeved? I have the same setup but using the lokar cable it moves like butter. The offset I have is about the same as you.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
07-24-2017, 04:02 PM | #4 |
Longer cable and loop it?
07-24-2017, 04:17 PM | #5 | |
Are throttle cables supposed to have a plastic sleeve? I don't believe my cable has a sleeve (Like I said, it was cheap). As I look at other member's setups, it seems like a bend like that is pretty normal. In fact many have a much more severe "S" curve and it still seems to work fine...Maybe I just need a better cable? Posted via Mobile Device |
07-24-2017, 04:25 PM | #6 |
Old member
The cable should have a plastic sleeve and a Teflon sleeve. Mine works fine.
The small cable inside the S/S sleeve is grabbing the sleeve. I would buy a new cable and it should be fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-21-2020, 02:38 PM | #7 |
@ JMD said "I don't think it's been discontinued, part number is XBAG-6164". That is a Lokar product that is available from my understanding. I was on the phone this morning with them talking about the 6164 product and they had it. My question is what throttle mounting bracket are you using because lokar said they do NOT have one (throttle mount bracket) for a TBI setup to go with the XBAG - 6164 assembly.
Thanks for your help! Eric |
