Old 07-28-2017, 07:36 PM   #1
davepl
davepl's Avatar
Any way to crimp a new end onto a park brake cable?
I've run into this a few times now, particularly doing rear disc conversions, where I need to crimp the "end" on a park brake cable.
I've got a swaging tool but the aluminum ferrules have no chance of standing up to that kind of tension.
Is there an end or a process you can use to put the "stopper" on the end of a steel cable?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-28-2017, 08:02 PM   #2
mike16
Re: Any way to crimp a new end onto a park brake cable?
go to a local area airport where general aviation aircraft are serviced. Find an aircraft mechanic and show him what you need doing. he will probably have the tools or if not he should be able to direct you to an FBO that has the capability to crimp your cable ends. its a common enough procedure in general aviation
mike16 is offline   Reply With Quote
Old 07-28-2017, 09:34 PM   #3
Lunnb
You might want to talk to someone that works on lift trucks , Crown , Bauer , etc . Many a time I have crimped ends on steering cables using a crimping tool ( arm strong , we didn't have a fancy assed power crimped ) and malleable cable clamps .
Lunnb is offline   Reply With Quote
Old 07-28-2017, 10:40 PM   #4
samkost
samkost's Avatar
Dave,
You mentioned an aluminum swage on a steel cable.
As an Overhead Crane Operator for a local Aerospace Company , I have used many styles of swagged wire rope rigging for certain Crane moves and lifts.
Here are a couple of links:
Some different swage styles from the Crosby Group.
West Coast Wire Rope and Rigging
A particular steel swage fitting called a swage button and the correct crimping tool (tons of pressure) may be required with steel cable for a strong terminal connection of 98% proof load.
https://www.thecrosbygroup.com/wp-co...over_LoRes.pdf
http://www.wcwr.com/
Hope this helps,
Sam
samkost is offline   Reply With Quote
Old 07-29-2017, 12:20 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If there are still any logging supply outfits near you, they might be able to fix you up -- if they can handle a job that small. Many years ago our local Ace Hardware crimped my brake cable ends and they are still holding. But the store somehow lost (or threw out) their crimping equipment.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-29-2017, 10:25 AM   #6
duallydude63
find a shop thats dills with cable for heavy equipment they should be able to help U !!
duallydude63 is offline   Reply With Quote
Old 07-29-2017, 01:24 PM   #7
68Gold/white
Heavy duty truck supply businesses, also.
68Gold/white is offline   Reply With Quote
Old 07-29-2017, 03:08 PM   #8
midniteblues
midniteblues's Avatar
I've already slipped a good fitting peice of steel tube over the cable and welded the ends.
If its a decent size cable a few holes drilled in the tube for spot welds would help too.
A bubba fix for sure and i wouldnt recomend anyone doing it on a ebrake cable but it worked for me on those notorious s10 hood latch cables that always seem too fray and break.
Speaking of frayed cable ends, a peice of shrink wrap on the ends helps stop the fraying and from getting poked by the strands.
YIKES! Them things hurt.
Ebrake's and the cables are something too take very seriously.
it could be your last ditch effort bringing your vehicle to a stop if you have a complete hydrolic failure.
Just a reminder as alot of them are called parking brakes anymore and thats what most know them as.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-29-2017, 10:05 PM   #9
Grumpy old man
Grumpy old man's Avatar
Buy a new cable and be done with it !
Old 07-29-2017, 10:25 PM   #10
dennislbrooks
dennislbrooks's Avatar
If 1/8" cable, use 5/16" steel solid rod. Drill a 1/8" hole thru the middle - end to end--- about a 1/2". Now cut off a 1/4" to 5/16" --whatever is right. Place cable thru leaving a little out. Use a Nicopress tool of correct size to crimp. Use mig to just spot the cable on the end. I have done this many times.
I have a suitable nicopress tool - about 2 foot long handles---and I believe the steel nicopress sleeves can still be gotten for fencing. Look up nicopress on web.
We used them on 109 steel open wire. Brass ones were used on 080 copper clad and pure copper 104. Telephone and telegraph wires. Open wire was phasing out early 70's.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-30-2017, 12:28 PM   #11
davepl
davepl's Avatar
Who sells custom length cables I can buy one from?
My case is when the stock cable isn't the right length, and you have to go longer (or even shorter sometimes).
Old 07-30-2017, 01:22 PM   #12
dennislbrooks
couple pics --if all else fails give me length and I will make you one.
Old 07-30-2017, 01:29 PM   #13
davepl
davepl's Avatar
Thanks Dennis.... I have the tool, but what are you using for ferrules that has been holding up? Steel or aluminum, and where are you getting them, and anything special to know about crimping them on?
I also see you have a rounded bead after the ferrule. Welded? I've tried tacking the ferrule on with a TIG but it didn't seem to help, still ripped off when I used a lot of force on the pedal.
Old 07-30-2017, 01:41 PM   #14
dennislbrooks
solid steel rod -- drill hole -- make ferrel as long as allowed --- crimps -- then I spot end with a MIG. Use smallest hole on nicopress that you can still complete crimp --- crimp more than once depending on ferrel length.
Old 07-30-2017, 02:57 PM   #15
toolboxchev
Good to know, One more for the tool box of tricks to fix!
toolboxchev is offline   Reply With Quote
