04-13-2004, 10:31 PM | #1 |
change front clip 73 to 80 on 81 to 87 cab???
Hi.. everyone...
here picture i draw where there is hole on front that design for 81 to 87 chevy cab.. that how i saw.. but also other picture i draw point where has 2 hole on front cab left and right near hood hinge that design for 81 to 87 but.. how 73 to 80 can hold up hood in back when you go over 55 mph? does it shake? 73 to 80 has support posts on left and right in front of windshield. 81 to 87 don't have support posts to hold hood in back only front.. so i wondering how it goes?? also other question... here picture file cab-1 i draw where hole on front of windsheild does it hurt when rain water go inside from hole make more rust? do it suppose to weld cover hole if someone wish install front clip for 73 to 80? i just learning about your experience. thanks Andy |
04-13-2004, 10:32 PM | #2 |
cab-1
04-13-2004, 10:32 PM | #3 |
cab-2
04-14-2004, 02:14 AM | #4 |
04-18-2004, 01:36 AM | #5 |
Anyone know about this????
04-18-2004, 03:47 AM | #6 |
i would weld the holes in the cowl up, water *may* get trapped in there, and rust it out. water in that area is the reason i scrapped my 82 cab. as for the ones for the hood hinges, you could let them go, as the area that they open up into has a direct path for water to drain out. this is the same area used for the kick panel vents. the cowl panel (part of the cab) on 73-87 trucks are the same, save for the slots for the hood hinges on an 81+ cab. you shouldnt have any problems bolting the hood bumpers to the cowl panel.
04-27-2004, 02:26 AM | #7 |
anyone,,
i diecde going put 73 to 80 front clip on my 85 pickup.. and should i use mount for radatior support from 81 to 87 or get other mount from 73 to 80?? pls let me know... and i hope hood will hold get bump from wind cuz 85 cab dont have bolt to support hood in front of windsheild. what about Wiper should i replace wiper to 73 to 80? to let hood fit it?? |
04-27-2004, 04:37 AM | #8 |
driving is in my blood
Not exactly sure what your asking [not trying to be rude, sorry] but the hood only bolts on with 4 bolts, 2 on each corner in back. No other spots. I would swap everything over: fenders, hood, radiator support, inner fenders
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-04-2004, 12:30 AM | #9 |
You will have to use the wiper arms from the 73-80 truck if you're going with the 73-80 fenders and hood. The shafts are shorter because they run under the hood. I'm currently in the process of completely redoing my 79 and I'm using an 85 cab and so far everything is going ok.
05-04-2004, 02:04 AM | #10 | |
