08-01-2017, 12:51 PM | #251 | |
Re: What did you do to your truck today part IV
08-01-2017, 03:23 PM | #252 |
Yes I'm happy with the doors I don't know if you can see within the pictures but the fit is pretty good around the edge happy with them I'm going to try to get the fenders now I got a whole complete bed and everybody said don't buy it I bought it I'm pretty happy with that besides the headboard the tailgate pretty nice
08-01-2017, 03:30 PM | #253 | |
Maybe there's a way to fix it but I found stock fenders with rusted bottoms. Seemed easier to patch them then trying to cut up new fenders. |
08-01-2017, 03:35 PM | #254 | |
08-01-2017, 03:38 PM | #255 |
Also if I try new ones there's two places that are pretty close to me Brothers trucks in Corona and car and truck shop in Anaheim I live fairly close if they don't fit I can take it back you probably have to do shipping
08-01-2017, 03:49 PM | #256 | |
Maybe the gap won't bother you, it sure would save a lot of work and then you know there's no hidden rust. |
08-01-2017, 03:56 PM | #257 |
got one door frame stripped and reprimered and installed new door check. Found some rust at the bottom of the door that will have to be POR-15'd or blasted, but not too bad....yet. Even came across the original paint(Light Blue).
08-01-2017, 06:04 PM | #258 |
Junior Member
@rvrfoot How'd the repop door fit?
08-01-2017, 06:41 PM | #259 |
08-02-2017, 12:35 AM | #260 |
washed it it's been yrs (2014) since I washed it started clay bar ran out of time
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
08-04-2017, 11:00 AM | #261 |
Sanded the firewall to 600 grit. Few more spots and then a good cleaning and masking and ready for paint!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-07-2017, 10:31 AM | #262 |
I got the engine & trans pulled out, pressure washed the 57 years of dirt and oil off of everything...I also power washed through what was left of the frost plugs. ;-)
Engine on engine stand now! |
08-07-2017, 06:47 PM | #263 |
Got some paint down. Now for cutting and buffing and it should look almost perfect.
08-09-2017, 10:46 AM | #264 |
It's Better With Nitro
After about 6 hours of sanding, I finally got some stain on the bedwood. A few more rounds of sand-then-stain, and I hope to get some urethane down this weekend.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 08-09-2017 at 11:26 AM. |
08-09-2017, 11:22 AM | #265 |
08-13-2017, 10:58 PM | #266 |
I installed my roll pan today.
08-14-2017, 08:39 AM | #267 |
Got the pipes installed, Woke up half the subdivision getting to the shop, but what the heck - they had to wake up anyway! Dan took his time and had to route carefully run around the oil filter and transmission pan, I have torsion bars so he was able to bring the pipe in the center of the arch and go to the rear, good clearance.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 08-15-2017 at 10:55 AM. |
08-14-2017, 11:22 AM | #268 |
Installed my new auto meter gauges and a clock.
08-14-2017, 12:17 PM | #269 |
More rust repair. This is very intimidating as it's my first time but I think it's coming out ok. Nothing is welded yet. Gotta fit floor pan next.
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
08-14-2017, 03:35 PM | #270 |
run fuel line from tank
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
08-14-2017, 03:52 PM | #271 |
Replaced shifter bushings , installed press on door seals, buffed out the paint and installed some Cragar S/S.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-14-2017, 05:15 PM | #272 |
WOW,, that floor pan is shot!... Have you ever thought of just adding one of those glass bottoms in there instead? you know,,, Like the ones they have on those glass bottom boats?.. you could cruz around and see what you pass over then
08-14-2017, 05:47 PM | #273 |
That would be pretty cool. I could wave to the squirrels as they run under the truck...
08-14-2017, 07:47 PM | #274 |
Put on my new window and vent window.
08-14-2017, 07:48 PM | #275 |
