#26 |
![]() Join Date: Jun 2002
Re: Anyone else doing Ram Air?
Keith, I just realized your dad is Van Sizemore. I remember reading about his lightweight GTO in High Performance Pontiac back in 2003 or 2004. It's a great car with a heck of a story behind it.
I've had a few Pontiacs in my life, all I have left is a '79 Trans Am 400 4-speed and a 73 Firebird, but I dig the old Poncho's. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#27 | |||
If you are asking about the ductwork itself I like what WilliamFd55 and Andy are using as shown in this thread. Quote:
https://www.msn.com/en-us/autos/clas...NnY?li=BBnb4R5 Reminds me of a story he used to tell, about when he was older and met someone from his youth. The guy asked "...did you used to be Van Seymore?" (lol)
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-03-2017 at 08:11 AM. |
#28 |
Looks great. I have a 5.3 and made a cold airbox like Andy's red truck. Prior to the box incoming air temp was 160-200 degrees from under hood. After the air temp is now ambiant. I get no ram air effect.
If you take care to insulate or route the air tube you can further reduce temps. I elbowed mine up out of the wake of the radiator.
71 C-20 Custom Camper California Truck |
#29 |
I believe for every 20% you reduce air temp you can gain up to 6% hp if you do the carb/ injector mods/adjustments to match.
Stan 67 swb BLU MULE posted via flip-fone |
#30 |
Science it up! Use a multi tester and a cheap thermocouple to measure air temp under the hood vs in the intake system.
https://www.youtube.com/watch?v=tG8pjoe061k I'm a believer in cold air intakes, especially at the track. It's not uncommon to see underhood temps in the 130 degree range before a run and that's a power killer. I mainly fool with EFI and all that sort of data is available within the software.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
#31 |
BlahBlahBlah
To me I dont care about the semantics of whats going on with it. I think you did a great job and no matter what you call it you made something cool that helps not hinders your engine performance.
But after reading this thread if it was mine Id make a cool sticker to put on the wide black edge, something that is factory looking that says ... Ram Air for 67' or insert whatever your truck is.
#32 | |
![]() Join Date: Mar 2000
Saskatoon, Saskatchewan Canada |
#33 |
Well done!
#34 |
This is what I did with mine and it dropped the air temp by an average of 20 degrees when the outside temp is around 100. I think it helped with throttle response but did not notice any better gas mileage. The engine is computer controlled fuel injection.
69 Chevy 4x4 383 Power ![]() |
#35 | |
![]() Join Date: Apr 2005
![]() ![]() I built this setup for the Farm Truck. I'm not sure how much HP I gained, but I know it reduced my IAT's by 15 to 20 degrees. I need to do something similar to my Suburban, but I've pretty much run out of real estate under the hood... ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-04-2017 at 08:33 AM. |
