Old 08-02-2017, 10:47 PM   #1
big_moss
big_moss's Avatar
Picking up 350 sbc
What's up everyone? Getting to the point of my build where I'm choosing the motor for my 51 build on a custom s10 frame that will be on air ride. The plan at first was to go ls but they are just everywhere right now so I've decided to go a different rought. A friend of mine sold me a 350 sbc seems to be in good shape my question is what should I shoot for if I'm wanting a dependable cruiser with some good thump behind it that I can take anywhere wanted to do a 383 but also thought about a 355 thanks for any input
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 08-02-2017, 11:10 PM   #2
mr48chev
mr48chev's Avatar
Re: Picking up 350 sbc
Run the 350 for a season and see how you like it. I say that with reservations. One is if you know the rig it came out of and how it ran and did all around in it.
That doesn't mean you can't put a thumper cam and performance intake in/on the 350 before you run it though. I've got enough left overs from old builds or engines that had issues that I could easily take a stock 350 and turn it in to a nifty sounding great looking small block for not a lot more money than a serious night out on the town. That money was spent years ago but a cam kit, intake, gasket set and set of nice valve covers won't break the budget if you shop around a bit.
That said a 355 is just a 350 with oversize pistons in it. That might be the next step if the engine is a bit tired. 383 is a bored out 350 block with a cut down or custom 400 crank in it. Several vendors including National auto parts or you can even find complete kits on Amazon https://www.amazon.com/s/ref=nb_sb_n...3+stroker+kit+ Takes some work on the block but that's an option.
My ongoing truck projects:
Old 08-03-2017, 09:36 AM   #3
OutlawDrifter
Just remember, an engine that has a rough idle isn't much fun in traffic and generally needs a good stall converter to get it into the power curve faster. Most people tend to over cam an engine just to hear it, then complain about its street manners. I have been guilty of this myself, but it sure sounded good at a stop light.
That block appears to be an older non-roller cam block, based on the perimeter bolt valve covers. If you know it's in good running condition, I agree with the statement to just run it for a year and plan your engine build after you know what you expect out of it.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-03-2017, 10:01 AM   #4
Speedbumpauto
Speedbumpauto's Avatar
Rule 1: There is no replacement for displacement.
Rule 2: If considering downsizing, see rule 1.
Speedbumpauto is offline   Reply With Quote
Old 08-03-2017, 10:04 AM   #5
Indian113
Indian113's Avatar
Have you done a cost comparison on a Complete Rebuild of your SBC and buying, installing a 5.3 ?
Indian113 is offline   Reply With Quote
Old 08-03-2017, 12:22 PM   #6
1project2many
Sorry, it's just one of those days.
1project2many is offline   Reply With Quote
Old 08-03-2017, 01:04 PM   #7
LCA1971
LCA1971's Avatar
Either engine would be a good one! 350 or LS. Parts are everywhere for these engine's! Here's a good web site to look at for part's, Racingjunk.com. Best site out there to get part's...
Chris
LCA1971 is offline   Reply With Quote
Old 08-04-2017, 02:08 PM   #8
buggy5872
buggy5872's Avatar
If you go with the 350 make sure you run the correct oil. Common off the shelf oil is no longer compatible with flat tappet camshafts. It will wear out quickly. Brad Penn and Joe Gibbs makes High zinc racing oil. Oil companies took the zinc out due to EPA regulations.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 08-07-2017, 02:51 PM   #9
Coupeguy2001
Coupeguy2001's Avatar
Hot rod magazine did a series on how to build a 350 several years ago. They take a 190 horse 350 and get it up to 400 horse. not necessarily cheap, but doable.
It might still be on their website.
Also,they did the same with a junkyard 350 to prove that there are really good engines just waiting for someone to pick the bones of the wrecks
Coupeguy2001 is offline   Reply With Quote
