08-04-2017, 02:44 PM | #1 |
Do I Need To Relocate Rear Shocks W/ 3" Drop Coils?
I'm not going to drill any holes in the frame, so I guess this will determine whether or not I try out a set of 3" drop coils in the rear.
08-04-2017, 03:17 PM | #2 |
Re: Do I Need To Relocate Rear Shocks W/ 3" Drop Coils?
Move the mounts or find a shorter shock that will not bottom or top out
08-04-2017, 03:54 PM | #3 |
I appreciate your response. So if I just install some high quality shorter shocks, I won't need to relocate with 3" drop coils? If that's the case, that's great news. Do you have a recommendation for the shocks?
08-04-2017, 05:19 PM | #4 |
08-04-2017, 05:30 PM | #5 |
I'm no expert but I was told four or more inch changes things up, I did go with four inch spring drop and got the shocks , track bar ( adjustable one )and relocation shock mounts. But like said you may need to go with three inch short short shocks.
Posted via Mobile Device |
08-04-2017, 05:55 PM | #6 |
They sell relocation kits that use the same holes as the stock ones.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-04-2017, 06:10 PM | #7 | |
08-04-2017, 06:11 PM | #8 |
Do they Demian? That would be great! Off the top of your head, do you remember the vendor/s?
08-04-2017, 07:19 PM | #9 |
Not hard to relocate shock and use the stock shock you have ,That's what I did there is a thread around here somewhere . Just a little fab work oh here it is
http://67-72chevytrucks.com/vboard/s...ock+relocation
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
08-04-2017, 07:28 PM | #10 | |
08-04-2017, 09:12 PM | #11 |
I've heard 4" or more needs the relocation, adjustable track bar and shocks. Mine was 4" down when I got it and it rode like crap, rides good now with the above added goodies. I got my short shocks from ece I think.... don't remember the name but they are black...
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-04-2017, 09:43 PM | #12 |
HDFF Thanks for sharing! When you got your truck, already lowered by 4", was it still riding on shocks that were too long?
08-04-2017, 09:44 PM | #13 |
Sorry. Just read your reply more thoroughly. Thanks again.
08-04-2017, 10:51 PM | #14 |
I put 3'' lower rear springs on the rear of mine. stock size shocks and stock mounts. they work and ride good.
08-04-2017, 10:58 PM | #15 |
I ordered 4" drop springs and shocks from ECE. No other changes. Just drove 900 miles. Rides great.
08-04-2017, 11:09 PM | #16 |
Thanks fellas! So with those final very helpful testimonies, I'll just order and install the springs. If I can discern a noticeable reduction in ride quality, I'll just pick up some shorter shocks.
08-04-2017, 11:27 PM | #17 |
Your stock shocks will bottom out.
08-04-2017, 11:57 PM | #18 |
That throws a wrench. Honestly, if I had a part number for some high performance short shocks (Bilsteins or something similar?), and not just some cheap lowrider shocks, I'd buy it all right now.
08-05-2017, 04:11 AM | #19 |
Bell tech offers a nice shock... I put those on mine
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
08-05-2017, 09:29 AM | #20 | |
Call ECE
08-05-2017, 12:17 PM | #21 |
Thanks Larry. Belltech is a performance name that I recognize.
Other Larry, does Early Classic sell performance brand shocks? |
08-05-2017, 02:38 PM | #22 | |
Ride quality is a subjective thing. A matter of opinion.
08-05-2017, 03:07 PM | #23 |
My pickup came with HD rear springs, and I've never noticed any harshness. I dropped the rear 2", and didn't feel any increase in stiffness. Not that the stiffness didn't increase, I just didn't really feel a big difference. I've ordered a set of 3" progressive rate Eibach springs for the rear, and if it rides a little firmer, I'm totally ok with that. I just want good handling. Not extreme. Just good. I already have a front sway bar and 2" Hotchkis front springs.
08-05-2017, 05:02 PM | #24 |
I been looking for my papers and finally found who I got my kit from, turns out it was easier too look under my truck and read the brackets lol. Early Classic , the guy there was very helpful, I told him what I have, short bed ,L6 ,with new LMC springs all around and all new parts up front and back, told him I wanted to level my truck by lowering the rear . He set me up with a four inch lowering kit for the rear-end that also come with K Y shocks, he's is the one to inform me four or more inches need the relocation kit. My truck now sites 32 inches all around . Three and less just springs and shocks is what I'm sure he said. Just look em up, good people.
Nick NGN |
08-05-2017, 08:19 PM | #25 |
I think one of the reasons for relocating the shocks that hasn't been mentioned is the angle of the shock as you lower the truck. I'm somewhere between 3-4" lowered with springs and my shocks were already leaning over at about a 35 degree angle. The shock relocation brackets allow you to run a stock shock and correct the angle of the shock so it's more vertical. I thought mine rode fine without the brackets, but I did actually notice a fair improvement after adding them. You do have to remove the stock top bracket though which requires cutting two rivets on each bracket.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
