Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-14-2017, 08:45 AM   #151
OLDYELLOW
OLDYELLOW's Avatar
Re: 1972 Medium Blue Highlander Blazer Resto
Can't wait to see it go together, looking good!
OLDYELLOW is offline   Reply With Quote
Old 08-17-2017, 02:35 PM   #152
85toyrunner
85toyrunner's Avatar
Looking great!! Love the color!
72 K5, 4x4, Medium Olive Green project
85toyrunner is offline   Reply With Quote
Old 08-20-2017, 11:23 AM   #153
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I cant believe I missed this build Pete. I enjoyed your K20 build. So I just read through this one and love the attention to detail. Signing on for the rest of the build
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-30-2017, 06:19 AM   #154
dirish
dirish's Avatar
Wow, I read it all. What a awesome build.
Watching impatiently! Great work.
dirish is offline   Reply With Quote
Old 09-03-2017, 05:53 PM   #155
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys for the encouragement! I've got more detail pics I'll post up soon. Just a quick update - we've got a rolling chassis. Axles were rebuilt with 3.73 gears and rear limited slip. The dust shields were replated with fresh cadmium. I had the original steering box rebuilt by Red Head in WA with a quick ratio to be joined with a replated pitman arm and a repro rag joint.
Old 09-03-2017, 05:55 PM   #156
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Chassis
Old 09-03-2017, 06:00 PM   #157
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The OEM has tank couldn't be plated so I went with a metal aftermarket piece. The aftermarket fuel neck wasn't soldered on so couldn't be sweated off. The old neck was cut near the tank and spliced onto the new tank. I did have the OEM straps replated and these turned out great. The anti squeak pads cleaned up nice so I'll reuse them. Found a NOS sending unit to use.
Old 09-03-2017, 06:03 PM   #158
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tracked down a NOS set of accessory shocks and steering damper - Pleasurizer Delco. Will be attached with replated OEM hardware.
Old 09-03-2017, 06:06 PM   #159
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'll have the tub and doors hung before hauling the chassis back home. I'm using NOS latches, strikers, and actuators with replated hardware. The latches and strikers were replated secondary to shelf wear.
Old 09-03-2017, 06:07 PM   #160
DeadheadNM
Carpe manana
DeadheadNM's Avatar
NOS door handles
Old 09-03-2017, 06:09 PM   #161
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Send unit.
Old 09-03-2017, 06:15 PM   #162
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Pete your attention to detail and commitment to NOS parts is inspiring. For sure another "Truck of the Month" in the making and possibly another Truck of the Year " and it couldn't happen to a nicer guy !!!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-03-2017, 08:28 PM   #163
IronCanine
I'm trying....
IronCanine's Avatar
L-L-L-Love it. Definite leader in the clubhouse for TOTY. So psyched for this Sunday treat.
IronCanine is offline   Reply With Quote
Old 09-03-2017, 09:36 PM   #164
gringoloco
A guy with a truck
gringoloco's Avatar
Astounding!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-11-2017, 02:14 PM   #165
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I really appreciate you all following along. I'd narrate more but my time for this build has been constrained and I'm trying to hustle: we have a now 9 month old daughter and she gets priority. Never enough time in life for everything is there?
Since she is napping and I happen to have a spare moment I thought I'd add some more documentation pics that I've not yet been able to post both to jog my memory and to help others on future builds. It'll be a motley assortment but hopefully useful for folks down the road.
Parking brake cables and components. Take a look at the stamped date on the parking brake: 1-25-72, a non invasive way of narrowing the date(s) of the build month for a truck (this k5 was assembled in February 1972). That little clip is same for the brake line along the booster bracket.
Old 09-11-2017, 02:15 PM   #166
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Brake cables...
Old 09-11-2017, 02:21 PM   #167
DeadheadNM
Carpe manana
DeadheadNM's Avatar
More...BTW - my K1500 GMC has two springs that secure the rear drum cables near the rear leaf springs to the under surface of the tub. I'll try to add pics of these springs at a later date as I believe them to be OEM but were missing from the blazer.
Old 09-11-2017, 02:24 PM   #168
DeadheadNM
Carpe manana
DeadheadNM's Avatar
more cable pics.
One pic shows the rear fender supports that are located at the anterior wheel opening: note the inferior (exposed) bolts are carriage bolts and these were painted with the body so in my case the heads were blue. Bolts are same carriage bolts used to assemble the bed.
Another pic shows the components of the rear fender splash shield. NOT shown is the two-piece clamp used to secure the gas filler hose and the vent hose both coming from the fuel neck to the gas tank on the LH side. The upper, inner bolt of the bracket for the splash shield holds the hose clamp pieces in place.
Old 09-11-2017, 02:32 PM   #169
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Misc interior pics...the washer fluid hoses were secured with a factory zip tie as shown. Last pic is of the steering column and shows the stainless Philips head screws that secure the column "plate" to the fire wall.
Old 09-11-2017, 02:35 PM   #170
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's the ebrake cable attachment inside the cab....note location of the clip for the sending unit wire
Old 09-11-2017, 02:42 PM   #171
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Brake booster mounts and brake line routing...
Old 09-11-2017, 02:44 PM   #172
DeadheadNM
Carpe manana
DeadheadNM's Avatar
more brake...pics taken AFTER the frame clips had been removed
Old 09-11-2017, 02:48 PM   #173
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Misc steering column related...
Old 09-11-2017, 03:08 PM   #174
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a couple more chassis pics. The gold color of the GM Pleasurizer shocks looks cool and matches the cadmium of the front axle dust shields nicely.
Steve and the guys at South Coors Truck Salvage did a great job rebuilding the axles, transmission, and transfer case. They rebuilt the axles and t-case for my K20 also. Steve has been a 67-72 Chevy truck fan forever and still has the 69 Chevy his dad purchased brand new from Ed Black's Chevrolet.
The frame was sprayed in chassis black as were the skid plates. Eric and the guys at Mild to Wild sprayed black bed liner as the undercoating to the floor pan and inside of the inner fenders and rear wheel wells.
Old 09-12-2017, 12:40 AM   #175
Andrew S
You mention a "sending unit wire clip" a few posts back, did the Blazers have a parking brake sensor, or is that clip for the hydraulic brake light switch wiring? Great build, thanks for documenting so thoroughly!
Andrew
'72 K20
Andrew S is offline   Reply With Quote
