08-15-2017, 02:28 AM | #26 | |
Before and After
Re: 5.3 swap into 72 C-10 Part list.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
08-15-2017, 11:36 AM | #27 |
Before and After
I'm confused about the oil pan from the CTS-V.
2004-2005 CTS-V ran a 5.7l (LS6) 2006-2007 CTS-V ran 6.0l (LS2) 2008-2014 CTS-V ran 6.2l (LSA) Will all or any of these oil pans fit a 5.3l (LM7)? I just don't want to order if it will not 100% fit.
08-15-2017, 04:50 PM | #28 | |
this is what i am using. GM Part # 12631828 - GM 2008-2015 Cadillac CTS-V oil pan, gasket, stock baffle, and mounting hardware GM Part # 12611129 - GM 2008-2015 Cadillac CTS-V Windage Tray GM Part # 12584738 - GM 2008-2015 Cadillac CTS-V Oil Dip Stick Tube GM Part # 12584737 - GM 2008-2015 Cadillac CTS-V Oil Dip Stick GM Part # 12621299 - GM 2008-2015 Cadillac CTS-V Oil Pickup Tube |
08-15-2017, 08:54 PM | #29 |
I have all the ctsv pan numbers I used in my suburban build thread.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-16-2017, 01:06 PM | #30 |
You can use the v8 perches but you'll need the one bolt mounts. 73-up perches allow you to use the clamshell mounts which are preferred. I think they'll let the engine sit just a tad bit lower too
08-16-2017, 03:22 PM | #31 | |
Before and After
For what it is worth, the Canadian GM dealership says the part numbers change from US dealers to Canadian Dealers.
08-16-2017, 03:26 PM | #32 |
Before and After
You have a 6.0l in your Burb, is there a difference in the 5.3l block?
08-16-2017, 04:17 PM | #33 |
08-16-2017, 05:03 PM | #34 |
I used the numbers I got off a US vendors site and there was no need to cross up. Also everything I found said the stock truck windage tray works with the CTSV pan.
Saskatoon, Saskatchewan Canada |
08-17-2017, 06:24 AM | #35 |
I think you need to find a new parts guy.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
08-17-2017, 11:09 AM | #36 |
Before and After
I called another shop, they were happy to use these part numbers. Sometimes i wonder how these parts "people" can keep their jobs. Ill check stealership pricing against GMPartsDepot.ca
08-17-2017, 01:05 PM | #37 |
I like getting my own part numbers online, then confirming them at the parts counter.
