08-08-2017, 12:52 AM | #1 |
Single red wire on top of sending unit?
How does it attach? 85 swb gmc. Not the ground, it's a single wire and kinda looks like it has a little boot over where it attaches.
08-08-2017, 01:08 AM | #2 |
Re: Single red wire on top of sending unit?
which sending unit?
what engine? |
08-08-2017, 06:24 AM | #3 |
305 and passenger side. Trying to drop the tank and would rather not just cut it.
08-08-2017, 06:31 AM | #4 |
ohhhhh...ok...when you said sending unit I was thinking temp or oil..
08-08-2017, 06:34 AM | #5 |
It just pulls off a pin. The rubber boot holds it on. Don't cut it just pop it off. I usually unbolt the ground wire from the frame. It's easier to get at.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-08-2017, 06:34 AM | #6 |
unser that boot should be a stud with a nut holding a wire ring terminal...should also be a ground wire that is a blade connector |
08-08-2017, 06:44 AM | #7 |
gas sending unit
08-08-2017, 11:15 AM | #8 |
I doesn't look like it has a nut on it. Just kinda looks like a pin.
08-08-2017, 11:17 AM | #9 |
Some of the different manufactorers make them differently, yours may just have a male pin on the top that a female connection on the wire plugs into.
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
08-08-2017, 12:32 PM | #10 |
^^^^correct^^^^...mine doesn't but some do
08-15-2017, 10:16 AM | #11 |
78K & 79C Jimmys
The sender has a button to snap on it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-15-2017, 01:51 PM | #12 |
Thanks everyone. It was a button that came off pretty easy. Just wasn't sure.
