Old 08-16-2017, 07:23 AM   #1
6t727t2
Active Member
WTB need 12 rear dif bolts
Looking to buy 12 rear dif bolts, 5/16-18-1'' I think. For my '71 Blazer restore. I'm sure I'll find mine as soon as I buy these. Would off the shelf home depot Lowes stainless work ok? Thanks
6t727t2 is offline   Reply With Quote
Old 08-16-2017, 08:25 AM   #2
WETOWM
Re: WTB need 12 rear dif bolts
check out AMK PRODUCTS they have new ones
WETOWM is offline   Reply With Quote
Old 08-16-2017, 09:55 AM   #3
1rippen6
Lowe's stainless will work fine and look pretty also. LOL
1rippen6 is offline   Reply With Quote
Old 08-16-2017, 10:51 AM   #4
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Be sure to use anti-seize with the stainless so it can be taken apart at some point down the road. Galvanic corrosion between dissimilar metals will form if anti-seize isn't used as a barrier between them.
towbar is offline   Reply With Quote
Old 08-16-2017, 10:58 AM   #5
1rippen6
I could be wrong but I don't think that is the case with stainless to cast iron.
Old 08-17-2017, 11:14 AM   #6
towbar
towbar's Avatar
Absolutely right, less likely with cast iron, but if the bolts are holding on an aluminum cover or get exposed to a corrosive environment (beach, salt air, salt water, road salt etc) then the chance for corrosion increases. Personally I feel its good practice to use anti-seize when dealing with stainless in general to prevent galling...but to each his own.
