08-16-2017, 09:51 PM | #2126 |
A320 Pilot/USAF Retired
Re: Danny Boy is BAACK! w/ '55 Big Window
Its getting there!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-16-2017, 10:52 PM | #2127 |
Great pics, and truck is coming along.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-16-2017, 10:59 PM | #2128 |
Looks like a nice place. Bit by bit!! Question... will the coils get to hot down there?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
08-16-2017, 11:55 PM | #2129 |
Nah, should be fine. They're ordinarily mounted ON the engine right above exhaust manifolds and heat rises. Down there they're a little below the manifolds but the manifolds will be Jet Hot coated and beyond the piping will be wrapped.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
08-17-2017, 04:02 PM | #2130 |
Looking good.
Kim |
08-17-2017, 06:39 PM | #2131 |
Thanks Kim! What's the latest with your truck?
Stopped by the shop today to sort of "Show the flag" more than expecting to see much. A crossover radiator pipe has been fabbed from stainless steel and I'll polish it eventually. It will be installed with two very short hose sections. Of course no polish in the grip areas of the hose. It will run right behind and parallel to the fan guard. Still can't decide if I should paint or polish that? It might be body color red or powder coated gloss black or polished chrome-like. Oh well, to be determined. I also ordered a small fuel pressure gauge for the driver side fuel rail. Better than a plain black plug. Site wont let me upload the pic of it, says I have the wrong file extension - whatever that means?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 08-17-2017 at 06:50 PM. |
08-17-2017, 07:36 PM | #2132 |
Nice looking piece...Jim
08-17-2017, 09:37 PM | #2133 |
Well done!
08-18-2017, 04:42 AM | #2134 |
Can you show more of what was done to the water pump? I am trying to figure out how I am going to do mine.
08-18-2017, 09:47 AM | #2135 |
I dont have a picture now but will take one and post later.
Basically the inlet was cut off because it pointed the wrong way and a replacement inlet was welded onto the pump pointing straight up. That allowed us to fabricate the pipe I show in the photo above. The reason for all this is the cross flow radiator I used has its top inlet on the driver side - opposite to where the water pump inlet originally pointed.
08-18-2017, 11:08 AM | #2136 |
Dan, I love your build and the direction you have gone with it so far, but wouldn't it have been easier and more convenient to just get a radiator with the correct configuration? That pipe is a nice piece of work but it looks like it is going to make it difficult to reach anything on the front of the engine.
08-18-2017, 11:15 AM | #2137 |
Thanks Russ,
Yes I suppose it would have been easier to have used a different radiator. I'm frankly not sure why this one was used. EDIT: Ok, I asked. If the inlet and outlet are on one side the water runs down one side, doesn't flow THOUGH the core. Instead it takes the path of least resistance. It COULD have been done with a double or triple pass core but that would have added thickness I didn't need/want and necessitated using thin electric fans. I wanted the reliability of a mechanical fan.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 08-18-2017 at 11:27 AM. |
08-18-2017, 02:10 PM | #2138 |
nice crossover pipe!
me too. its funny, when I see people talk about losing all those horses I wonder where they are driving at 10/10ths all day every day. electric fans use a LOT of current, and that comes from the.... help me out folks.... ALTERNATOR. which is belt driven! so I guess the way to save hp is to take off something that is driven from the belt and put on. something. that is... driven... by.. hmmm
08-19-2017, 03:38 AM | #2139 |
Danny
Just a thought make sure that a bead is rolled into the end of each pipe, for clamping behind. Things are moving forward, great pics.. NC
Been there, wrecked that |
08-19-2017, 02:45 PM | #2140 |
Thanks NC, Yes Mike did that. It's not a big thing but I'm wondering if enough of the welds can be ground off so they won't be visible after polishing the pipe?
08-20-2017, 01:04 AM | #2141 |
Gee if you have to replace the water pump that could be a problem for a on the road repair.
I saw this a few years ago at a car show. I asked about cooling and what the set up was. It's a 2001 Camero Rad and Fans . It cools great even in 105+ weather. This is what I'm using in my build but with rubber hose. Mine is a 5.3 van engine with cable throttle. The Rad just drops in after clipping the lower inner strut on the core support. The best part is it's way less $$ then the aftermarket .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
08-20-2017, 12:08 PM | #2142 |
I find that GM has a bunch of water pumps for the 5.3
These are pic of my water pump from a 2005 Chevy Van. This may save you trouble in the future .
08-20-2017, 07:30 PM | #2143 |
I don't know if the WP from a 5.3 will fit a 6.0, I'd better find out!
08-23-2017, 07:31 PM | #2144 |
I've seen too many episodes of Overhaulin' or Garage Squad. I guess I'm expecting my truck to go back together in 30 minutes! Lol.
- The Dakota Digital HDX & modules are installed. But that doesn't address that holes were drilled & threaded into the dash struts for each to mount them. The wiring also had to be trimmed and terminated properly. - The steering column was FINALLY reassembled after the lost part was delivered. It looks great but is still not mounted to the dash so the wires for signal lights, etc can't be run/terminated. - PS reservoir & radiator overflow tanks have been mounted on driver's side of core support. - The ambient temperature sensor for the gauge is tiny and installed into the core support behind grill. - I ordered a liquid filled fuel pressure gauge to use instead of a plug in driver side fuel rail; it's installed and looks good. - Ordered but not installed are Cadillac CTS horns. Stock one is too big to easily hide. They're small and mostly plastic unfortunately but they're loud! These will be mounted in the wheel well when they arrive. - Today the knock sensors were being installed in the valley cover. It's all getting done but it just seems to be dragging.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 08-23-2017 at 07:40 PM. |
08-23-2017, 09:50 PM | #2145 |
I feel ya. I have been trying to get the engine and transmission back into my truck so I can move forward. Its amazing how many little holes, bolts, mounts, etc need to be figured out before the engine can go in. I still don't have the accessory placement figured out but I guess that can happen after the engine is back in its home. I've gone to the auto parts store everyday this week haha. I swear every time I go out there I'm staring at the same thing. The good news is, I've had plenty of time to clean the garage up while waiting for parts to arrive.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
08-23-2017, 09:58 PM | #2146 |
^^^ Thanks for the comments^^^
In my case the engine and trans had ALREADY been in the frame with the cab on and there was STILL problems with putting it all back together. But Mike keeps telling me, "Yeah, it's a '55 Chevy but it's still a custom built vehicle. Everything has to be fitted right for it to look right and perform right and that just takes time." I know he's right but damn!
08-23-2017, 11:10 PM | #2147 |
Oh and just because we're all truck guys I'll post a couple pic's of an early C10 Mike had in his shop.
This is not a frame off job but it looks nice from 10 feet. Up close the paint prep was not done well enough. A prior paint job's chips were not feathered out and could be seen in a few places. In the wheel wells and frame its a little crusty but it looks good for a long bed stepside.
08-24-2017, 04:21 PM | #2148 |
Your build is looking good.
08-24-2017, 06:20 PM | #2149 |
Yes it will seem like it's dragging, but before you know it you will have nothing else to do Keep up the good work.
08-25-2017, 07:37 PM | #2150 |
Friday, August 25, 2017
Mike wanted to run a better looking cover weld bead over the what he originally did on the modified waterpump neck. Glad he's trying to make it look pefect but it just adds time. Pump pulley was re-sprayed black and pump re-installed. Upper & lower radiator hoses were finally installed - all looks good & well fitted. Heater control valve was installed in passenger side wheel well. Dealer says there's a back order on steam control port plugs - I guess they're called? I've posted a pic of them. We can start the engine without them since if there's no water in it. But we're waiting on new plug wires to arrive and the driveshaft to be fabricated. Guy is running behind on that. Pleased with everything. PS: Site won't let me upload the photos - says missing a "security token" - What's that/How to fix?
