Old 08-17-2017, 11:45 AM   #1
bosephus
bosephus's Avatar
Will mini starter fit?
I have a one piece rear main block mated to a 61 manual bellhousing. The original design starter bolts to the bell while the mini would bolt to the engine block. Does anyone know if the mini would work? IIRC i have the 153 tooth flywheel. Thanks,Bo
bosephus is offline   Reply With Quote
Old 08-17-2017, 02:26 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Will mini starter fit?
It should. Make sure the holes are in the block. Mine are offset on the 400 block and no hole for straight set. Old Billet aluminum block with Izzuzu diesel starter before minis were available.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-17-2017, 04:33 PM   #3
bosephus
bosephus's Avatar
Hotrodding at its best right there, Thanks
Old 08-27-2017, 12:25 PM   #4
txinliner
txinliner's Avatar
I run one on my hopped up 6
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 08-27-2017, 12:54 PM   #5
rvrfoot
I have a 283 from a 58 to 62 and it will not.
rvrfoot is offline   Reply With Quote
