Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-19-2017, 11:33 AM   #251
Captainfab
60-66 Nut
Re: Impala SS Rear Disc Brake Brackets
All of my products are always available. The quantities are not limited to a one time run. I replied to your PM.
Old 08-20-2017, 10:54 AM   #252
AmmoRob
Has anyone found a backing plate to use or are you running without a backing plate??
AmmoRob is offline   Reply With Quote
Old 08-20-2017, 11:19 PM   #253
Captainfab
60-66 Nut
I assume you are talking about a dust/gravel shield? If so, I do not know of any stock application that will work.
Old 08-21-2017, 04:36 PM   #254
AmmoRob
Can you send me a paypal invoice for a set... Robcubs@aol.com
Old 08-21-2017, 11:15 PM   #255
Captainfab
60-66 Nut
PayPal invoice sent.
I am supposed to have the laser cut parts for these on the 29th.
Old 08-25-2017, 09:54 PM   #256
jessemthompson
Captainfab, I'm looking to switch to rear disk brake here very soon. I have a 72 and the back spacing on my wheels is perfect. I don't have room to be any wider. Would running the impala rear setup add any width to my rear end?
jessemthompson is offline   Reply With Quote
Old 08-25-2017, 11:35 PM   #257
Captainfab
60-66 Nut
Any of my 5 rear disc brake conversions are going to move your wheels and tires out about 1/4 inch. There is just no way around it. The rotor hats are thicker than a brake drum.
Old 09-04-2017, 07:49 PM   #258
dwcardfan
dwcardfan's Avatar
I need a set for 1972 12 bolt.
dwcardfan is offline   Reply With Quote
Old 09-04-2017, 11:03 PM   #259
Captainfab
60-66 Nut
I will send you a PM with ordering info.
Old 09-04-2017, 11:28 PM   #260
dwcardfan
dwcardfan's Avatar
I sent order through PayPal. Thanks
Old 09-08-2017, 03:29 PM   #261
dwcardfan
dwcardfan's Avatar
Will I need to install longer wheel studs since the rotor hat is 1/4 thicker? My lug nuts only have about 7 threads as it is now.
Old 09-08-2017, 11:38 PM   #262
Captainfab
60-66 Nut
Longer wheel studs would be a good idea. However I do not know of a OEM application for longer studs. You will have to look at aftermarket studs.
Old 10-04-2017, 10:14 AM   #263
dwcardfan
dwcardfan's Avatar
Got my brackets! Is this the correct way to mount them?
Old 10-04-2017, 10:39 PM   #264
Captainfab
60-66 Nut
Yes that is correct.
Old 10-11-2017, 09:52 PM   #265
dwcardfan
dwcardfan's Avatar
Thanks for the brackets! Worked great. I used longer wheel studs because I didn't have enough thread with the stock. I used Dorman 610-358 they fit a 97 ford aerostar. I had to drill the rotor wheel stud holes out to a 17/32.
Old 10-11-2017, 11:28 PM   #266
Captainfab
60-66 Nut
Thanks for the pic and the info on the wheel studs. Are those SAE or Metric? I didn't think about looking at Fords for wheel studs.
Old 10-12-2017, 09:23 AM   #267
dwcardfan
dwcardfan's Avatar
They are SAE 1/2 inch by 20 threads same as factory. My original wheel studs had a knrul diameter of .615 these are .612 but they were a press fit.
Old 01-02-2018, 01:14 PM   #268
thepartsguy
thepartsguy's Avatar
Will you email a paypal invoice for a bracket kit and the adapters to wayne8176@gmail.com please. My zip is 59901
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 01-03-2018, 12:41 AM   #269
Captainfab
60-66 Nut
Invoice sent and payment received. Thanks
Old 01-10-2018, 01:02 AM   #270
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 02-06-2018, 09:04 PM   #271
Muzzerati22
Want to buy a set, PayPal @emm112289@yahoo.com
Thanks! Enjoy the vacation 🤘🏻
Muzzerati22 is offline   Reply With Quote
Old 02-07-2018, 02:29 AM   #272
Captainfab
60-66 Nut
I replied to your PM and sent you a PayPal invoice.
Old 04-05-2018, 10:51 PM   #273
FM5332FF
Smile Re: Impala SS Rear Disc Brake Brackets
PayPal sent.
FM5332FF is offline   Reply With Quote
Old 04-06-2018, 12:21 AM   #274
Captainfab
60-66 Nut
Under what name was the payment made? I have not received any payments today for any Impala SS rear disc brackets.
Originally Posted by FM5332FF View Post
PayPal sent.
Old 04-06-2018, 10:25 AM   #275
FM5332FF
Chris Tyler. paid on April 3
