Old 08-20-2017, 09:09 AM   #176
_mg
Active Member
_mg's Avatar
Re: What did you do WITH your truck today?
This time relatives visited us.
_mg is offline   Reply With Quote
Old 08-20-2017, 01:57 PM   #177
65chevysub
65chevysub's Avatar
Spent a few hours stripping my passenger door down to the bare metal along with the door jamb. Took care of some rust issues before they get out of hand. Replaced the door check, and wire wheeled my sill plates and got them repainted.
65chevysub is offline   Reply With Quote
Old 08-20-2017, 01:58 PM   #178
65chevysub
65chevysub's Avatar
Spent a few hours stripping my passenger door down to the bare metal along with the door jamb. Took care of some rust issues before they get out of hand. Replaced the door check, and wire wheeled my sill plates and got them repainted. I also found out my Fremont Suburban was sprayed with the rust red primer before the Light Blue.
Old 08-21-2017, 07:53 AM   #179
The Rocknrod
Moderator
The Rocknrod's Avatar
Worked on the brake pedal push rod and setting the booster to master cylinder clearance. All set up on my bench, so when I get the truck back from paint jail install should be a breeze.
Old 08-21-2017, 09:40 AM   #180
jbgroby
jbgroby's Avatar
She made her First Cruise Night Debut after 11 yrs.
jbgroby is offline   Reply With Quote
Old 08-21-2017, 10:15 AM   #181
scoot_mcgrute
Took it out to an autocross with the local Porsche club chapter. I had a blast out there!
https://youtu.be/HWeNC8rFHX8
https://youtu.be/0UmdmEzzpEY
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-21-2017, 01:29 PM   #182
65chevysub
65chevysub's Avatar
Cool Re: What did you do WITH your truck today?
Beautiful GMC! What is the name of that color of Blue? I like it.
Old 08-21-2017, 02:28 PM   #183
jbgroby
jbgroby's Avatar
Canyon Blue and Olympic White, I like this shade better than the Varsity Blue from '60 - I felt it was too dark for my taste.
Old 08-21-2017, 04:19 PM   #184
lilblue_64
started out with a good weekend.....after changing out a bad fuel pump that has kept the old girl sitting for far to long, went to start her to find the battery dead....no biggie. Charged her up and nothing, battery was dead. So after another $150 bucks for a new battery finally got her running and spent the weekend quite happy, drove her to get her washed and gassed and whatnot. Started to drive her to work this morning and almost there heard a huge boom from under the hood and smoke started pouring out. After looking under the hood, the upper radiator hose burst, completely blew in half and sent fluid everywhere. Another $40 for new hose/fluid. Now I get to wash out the engine bay tonight because I cant tell if the smell is coming from the fluid that covered my engine block or if I messed something up when it blew.
lilblue_64 is offline   Reply With Quote
Old 08-21-2017, 05:44 PM   #185
65chevysub
65chevysub's Avatar
Is it a 1960 color or what year is it? I definately want my 65 Suburban that color of Blue( Wife even likes it which is a good thing) lol
Old 08-21-2017, 07:09 PM   #186
jbgroby
jbgroby's Avatar
Mid year 1960, and all year 1961. I have the paint chips card somewhere. The pain ship in Mississippi was able to do a direct match from the old paint code. I have no metallic in it.
Old 08-21-2017, 08:58 PM   #187
65chevysub
65chevysub's Avatar
Thanks. I looked on www.autocolorlibrary.com for years 57-63 and they don't have it listed. I like the fact it's a solid color, as I don't care for metallics.
Old 08-21-2017, 09:14 PM   #188
Buda63
Buda63's Avatar
Had a productive weekend working on the truck.
New speedo gear and housing, new speedo cable,
Finished aftermarket gauge wiring and installation,
New fuel lines, PO ran rubber throughout the truck
New shocks all the way around
New rear coils (stock height) PO had melted the old ones to lower the truck. Also had to weld in a new base for the passenger coil due to some rust.
Need to put on a parking brake and should be road ready.
Buda63 is offline   Reply With Quote
Old 08-22-2017, 08:04 AM   #189
jbgroby
jbgroby's Avatar
My mistake, its a '59 color
Old 08-22-2017, 11:55 PM   #190
vetnat
Buda63, love the 2 tone scheme on a stepside!
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 08-23-2017, 09:10 AM   #191
65chevysub
65chevysub's Avatar
Thanks jbgroby. I appreciate you looking that up for me.
Old 08-28-2017, 09:54 AM   #192
jbgroby
jbgroby's Avatar
With the threat of rain this past Saturday, the local Cruise-in canceled out, so I took her to dinner at Rips on the Lake in Mandeville. I was able to get a good picture looking down.
Old 08-28-2017, 11:15 AM   #193
Porterstoybarn
Burnouts!
Porterstoybarn is offline   Reply With Quote
Old 08-28-2017, 05:55 PM   #194
jayoldschool
Moderator
Drove it to my school shop so I could work on my 81 Cadillac that needs exhaust manifold bolts drilled out.
jayoldschool is offline   Reply With Quote
Old 08-28-2017, 06:26 PM   #195
Clrussell
Clrussell's Avatar
Slow day at work. Started the process of trying to get the 235 to run.
Carb kit and points should be all I need to make er run
61 apache
Clrussell is offline   Reply With Quote
Old 09-04-2017, 09:52 AM   #196
jbgroby
jbgroby's Avatar
Drove her to the Lake for some fresh pictures.
Old 09-21-2017, 10:33 PM   #197
53chevyforever
53chevyforever's Avatar
I finally finished my engine....406 cubic inch, scat crank, eagle 5.7 rods,
9.1 Keith Black pistons, comp cams 256 xe, gm vortec heads, edelbrock rpm intake, 700r4, 3.73 12 bolt gears. I built this engine for strong low end and mid range torque and to run on regular gas because the premium is so expensiive and will keep increasing I am sure. I will know soon if my patriot ceramic headers for a camaro will fit. I have 2 1/2 exhaust and Dynomax mufflers. Hoping for a strong running street truck to drive anywhere.
53chevyforever is offline   Reply With Quote
Old 09-22-2017, 08:28 AM   #198
jbgroby
jbgroby's Avatar
She looks great
Old 09-22-2017, 06:33 PM   #199
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Pulled my utility trailer back out of our back property before the rain came.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-24-2017, 09:31 AM   #200
53chevyforever
Finally found a vacuum guage...new chrome bezel and new face plate.
I have decided the back ground looks better the fawn color instead of the
black. Changed all the bulbs to number 1895 which are brighter than
the 57s. Extended all the wires to make it easy to pull the cluster when needed. After I make sure all is working will install in the dash.
