Old 08-24-2017, 07:18 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Spray-in Bedliners
Looking for recent experiences with spray-in bedliners. I'm starting to think about having mine done (instead of getting it repainted) and most threads I have searched are older. Things tend to change so I'm looking for more recent input. I just removed the plastic bedliner that's been in for well over 20 years and was pleased & amazed to find only a small amount of surface rust. This is not a show truck and never will be; the bed floor is a bit wavy and the wheel tubs are kinda beat up from decades of abuse (mostly firewood). From what I've been reading, a relatively thin liner that's extremely hard would work best for me. It's not like I'm gonna hurt the value of the truck -- as it is, it would take new sheet metal to turn it into something fancy.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-24-2017, 07:57 PM   #2
beadblaster
beadblaster's Avatar
Re: Spray-in Bedliners
I have used raptor liner on bumpers,underside of truck and it is awesome stuff.
beadblaster is offline   Reply With Quote
Old 08-24-2017, 08:04 PM   #3
Sweeet67
Does spraying it lower the trucks value? I'm thinking of spraying mine.
Sweeet67 is offline   Reply With Quote
Old 08-24-2017, 09:04 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have read several older threads with that viewpoint.... however, only if it will someday be made into a show-quality truck, or nearly so. For most of us with, um, "experienced" trucks, it doesn't matter so much.
So far I have found Line-X dealers more than three hours away so that may be out..... There is a Rhino-Liner guy about an hour from me. Haven't looked into Raptor yet, but I will.
FWIW, I have also been reading that installation matters a great deal with these products.
- Mike -
RIP El Jay
Old 08-24-2017, 10:33 PM   #5
clay68c10
clay68c10's Avatar
Install does make a big difference, if the liner separates at an edge it will let water in and hold it there. Not good.
I have a tailgate that I'm patching the inside bottom of because of that. It looked really solid until I started peeling the liner off. The areas where the the liner held in moisture were rotted thru. The areas where it was still sticking were rock solid. Bad prep damaged what was a rust free surface. It looked like they lined it over primer-covered single stage paint.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-24-2017, 11:02 PM   #6
71sierragrande
Petroleum User
71sierragrande's Avatar
The good stuff is thick, and its forever. I don't know the applier of mine, maybe rhino(just guessing). Linex possibly, but its rock hard.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 08-24-2017, 11:19 PM   #7
jocko
jocko's Avatar
I have a Rhino liner and I WISH I'd gotten a Line-X liner. My only recommendation - for looks and for water-tightness, is to only spray up to and underneath the bedrails, not over them. Yes, can detract value, but much less so (in my opinion) if not visible over the rails - but it is entirely up to personal taste and what you intend to do with the truck. There are many times I wish all my trucks had one and times when I'm glad my old trucks don't. If it's got dents, I'd leave it alone, they tend to show thru a bedliner pretty badly. Rhino and Line-X do great prep - I just like the look *and wear) of a Line-X one later. The only reason I got the Rhino is because there wasn't a Line-X dealer in the small town I used to live in.
Old 08-24-2017, 11:43 PM   #8
mongocanfly
mongocanfly's Avatar
I've had sevearal trucks with different liners applied both diy and professional. ...hands down line-x is the best by far...
mongocanfly is online now   Reply With Quote
Old 08-24-2017, 11:59 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
My 98 has had line x since before it came into the family in 04. It's still there and it's still in good shape. I'd use it again in a heart beat.
Tyler
Old 08-25-2017, 06:55 AM   #10
Thor94
I wouldn't own a pickup without a spray in liner. I've done both Linex and Onyx. Both extremely durable. Hard to say for sure, but Onyx doesn't seem to fade as much.
Thor94 is offline   Reply With Quote
Old 08-25-2017, 08:02 AM   #11
Mike C
Mike C's Avatar
Most of the posts agree with my experience as well. I wouldn't own a truck I use without a spray in liner over the rails.
And it's worth the 3 hour drive to get the Line-X done. By far the best liner and worth the extra costs and difficulty to get it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-25-2017, 08:14 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thanks for the input, guys, I appreciate it all. When the time comes (probably still quite a ways out) I will give top priority to Line-X, it seems to consistently get the best reviews. Just wish I had a dealer closer to me. Already planning on under-the-rail unless I can be convinced otherwise.
- Mike -
RIP El Jay
Old 08-25-2017, 08:50 PM   #13
Mike C
Mike C's Avatar
Just depends on how much you are going to work it I guess. I love the over-the rail on my 2500 HD, but I can see how a classic would look better with painted tops. All personal preference at that point.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-25-2017, 09:26 PM   #14
CG
BlahBlahBlah
Can Line-X color match? If I had a spray in liner I would want it over the bed rails. I like the liners that are matched to the paint color of the truck.
Old 08-26-2017, 12:45 AM   #15
ho70
ho70's Avatar
I went to a body shop and had the bedliner tinted to match my paint. I painted the underneath of my 70 Challenger. I would line my bed, but keep the liner uner the bedrails on these trucks
ho70 is offline   Reply With Quote
Old 08-26-2017, 08:25 AM   #16
mongocanfly
they sure can color match linex...don't know why but our local dealer has sprayed tons of yellow linex..http://www.linex.com/bedliners/xtra
Old 08-26-2017, 08:55 AM   #17
BIG ORANGE
BIG ORANGE's Avatar
I use a kit called Rocketliner, I get it at the local automotive paint store,
I've bought 2 kits in the past to be able to put more product on the surface, works great and goes on as thick as I wanna apply it.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-26-2017, 12:15 PM   #18
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I just had my girlfriends 93 pace truck bed Line X coated. It's very nice and looks great.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-26-2017, 01:15 PM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That looks great! Is it a standard color (if there is such a thing), or a custom color, or.....?
- Mike -
RIP El Jay
Old 08-26-2017, 01:18 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, now ya got me thinking.... I would prefer the look of under-the-rail, but the extra protection of over-the-rail is awfully tempting. Decisions, decisions
- Mike -
RIP El Jay
Old 08-26-2017, 01:43 PM   #21
Ol Blue K20
Doesn't show well in the pic but it's black (standard color). I've been working on her truck for over a year. It's finally looking like it should.
Dale
Old 08-28-2017, 03:38 AM   #22
County
How much does the Line-X treatment generally cost for a short wide bed? I've never done one.
County is offline   Reply With Quote
Old 08-28-2017, 01:05 PM   #23
68blazer
68blazer's Avatar
I used Raptor bedliner spray for my frame, under the cab and firewall. I will use it under the bed as well as in the bed when the bed is ready. if you never get rid of the truck it doesn't matter about the price of the truck lowering or raising, just my 0.02. anyways obviously I am for Raptor because if the area is prepped correctly it is great and you control how thick it's being applied. I want to make sure you know that I applied it myself and because of that if you go my route make sure you purchase the kit with a gun. you will need it. most kits have it with it just fyi. if you have any questions pm me and I can tell you all I know about it. good luck
p.s. U-POL is who makes it
68blazer is offline   Reply With Quote
Old 08-28-2017, 02:26 PM   #24
Coley
Coley's Avatar
New or newer truck...absolutely the way to go.
Classic truck....for me, nope.
I don't use my truck enough to warrant the need for something that heavy duty.
I do have a drop in rubber mat which suffices for most of the stuff I deal with.
I do like being able to see and access all that original steel.
It simply comes down tho'....to what you want, that is what counts with your truck.
my two bits,
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 08-28-2017, 05:47 PM   #25
jeffahart
jeffahart's Avatar
Line-x. I've used it on a few trucks, not this one, I have wood bed. Anyhow, once you get it sprayed in... it ain't coming out, it's a done deal!
White K20
jeffahart is offline   Reply With Quote
