Old 08-28-2017, 08:39 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Help identifying Driveshaft components
I'm working on a 71 C-10 400TH, 2WD. Full frame-off and until once done, everything is a mystery to me. Ask me if I've ever so much as drained a differential?
Anyway, next up is the driveshaft and axles, so I'm trying to determine how to approach disassembly. Problem is, I don't know the proper names (or even "code names" yikes), which makes things a tad complex. Anyway, here are three images with 10 areas of the driveshaft, with captions. The captions are numbered, which hopefully makes things easier. Any help appreciated. Thank you.
Images have been updated, thanks to board help.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-28-2017, 08:43 PM   #2
roboticjunky
Re: Help identifying Driveshaft components
3. Slip yoke 4. Tailhousing of the transmission 7. Slip yoke for the rear portion of the 2 piece driveshaft 8. Carrier bearing and housing 10. Rear axle Pinion yoke
Other numbers are correct.
roboticjunky is offline   Reply With Quote
Old 08-28-2017, 08:52 PM   #3
71CHEVYSHORTBED402
BINGO.............Thanks a bunch.
Tony
Old 09-06-2017, 11:21 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
If you're working on the driveshaft it needs to be properly timed and balanced as an assembly when finished.
This style carrier bearing is the hd style and won't break if the driveshaft isn't balanced but you may feel a vibration around 70mph.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
