Old 08-29-2017, 10:13 AM   #1
bbluma
Widest tire to fit in a stepside fender
Hey y'all, I'm curious to what is the widest tire meaning largest tread width tire you can fit inside a stepside fender? It'll be on a stock rear end and the fender is already cut cause of bad backspacing on current wheels.
I may just be missing a stepside thread about tires and all, and if so just post it please. Otherwise lemme know, and pics always appreciated
bbluma is offline   Reply With Quote
Old 08-29-2017, 02:33 PM   #2
scoot_mcgrute
Re: Widest tire to fit in a stepside fender
I'm rocking a 275 on mine lowered 7" in the rear. I had to roll the fenders and it's tight but clears with no room to spare. I'm on 18x9 wide wheels with 4.5" of backspace and just shy of a finger width clearance on either side of the tire.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-29-2017, 03:02 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
And ded sexy
Any spacer or anything?
Old 08-29-2017, 03:27 PM   #4
scoot_mcgrute
No spacers, just a quick BS measurement and a whole lot of hoping they fit
1966 Army Truck
Old 08-29-2017, 03:32 PM   #5
The Rocknrod
Moderator
A stock rear end?
Old 08-29-2017, 03:33 PM   #6
bbluma
That looks good! You same tire and everything all around? Thinking bout going big and little and trying to determine how big I can go in the rear. Thanks for the response!
Old 08-29-2017, 04:10 PM   #7
scoot_mcgrute
Originally Posted by The Rocknrod View Post
A stock rear end?
Yep, factory 12 bolt with a 5 lug conversion and that's it.
No sweat, I am running the same tire/wheel setup on all 4 corners. 18x9 Rev 107s with 275/40r18s
1966 Army Truck
Old 08-29-2017, 04:41 PM   #8
forestb
forestb's Avatar
I have 275's and they are rubbing like crazy. 5 inch rear drop and stock axle. They rub on both sides of both tires. I had rolled the fender but when it got painted he unrolled it. They used to have clearance on the inside of the tire next to the bed but some how that is not true after they put the bed back on. It is strange what works for some people does not work for others. If you are planning on getting a really large tire in the rear and rolling the fender be warned that the brackets that hold the inner support bars will not roll. I still can't figure out how scoot_mcgrute can have a 7 inch drop and not bottom out.
forestb is offline   Reply With Quote
Old 08-29-2017, 05:19 PM   #9
shp4man
shp4man's Avatar
Every time scoot_mcgrute posts a pic of that truck it brings back memories of when I was a staff car driver/messenger for the Army in about 1970. Not all good memories- a mixed bag.
I think there's supposed to be a small stencil that says "TMP 35(or whatever motor pool it came from)" above the front wheelwell.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 08-29-2017, 06:00 PM   #10
scoot_mcgrute
I have about 3/4" uptravel in the rear and hit the frame regularly, need to c-notch it this winter. I actually can't drive it to work right now because they have some massive bumps on the highway due to re-paving. Thought I was going to end up jumping my 3500 Dodge off one yesterday
1966 Army Truck
Old 08-29-2017, 06:16 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
From my thread:
Originally Posted by LostMy65 View Post
Here you go, Sean C.
295/50/15 are (11.6 wide and 26.6 tall)
I have a little less than 3/4" of space between the wheel and the bed inside panel.
3-1/2" backspace.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-29-2017, 06:21 PM   #12
forestb
forestb's Avatar
all I can say is be careful when buying your tires based on what everyone on here says. Not all trucks have the same spacing.
Old 08-30-2017, 06:55 AM   #13
PGSigns
PGSigns's Avatar
Also the tire you choose can have an effect on if it will fit. They all have different section widths. When I put new tires on the back of the 66 I went with the same size tire and changed brands. The new tires have a wider section width on the rims than the old ones. Needless to say the new ones rub just a bit on the inside when pulling into parking lots. The white letters are facing in and they are getting rubbed off. Will be a bit of trial and error and you may find a combo that wont fit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-30-2017, 10:12 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
325/50/15 Close to as wide as you can fit under a stock width 12bolt. Yes they fit under the fenders.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
