Old 04-15-2004, 07:05 PM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Loss of brake power after spindle install
Did anyone experience this?
I am thinking it is due to my "helpers" greasy hands on the rotors or the banjo fitting that I had to "tweak" to fit the caliper on the Western Chassis spindles.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 04-16-2004, 01:03 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My brakes feel the same, but I was careful to keep my hands clean, and wipe everything down with a clean rag and brake cleaner. You might make sure nothing is contaminated, and that you didn't crack a brake line when you were bending them.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-16-2004, 01:06 AM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Unless the "helper" soaked the pads/rotors, most greasy finger prints will burn off after a few stops. Check for leaks and bleed the system well.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-16-2004, 01:09 AM   #4
ocbaud
Garage Queen Material
make sure the brakelines arent bound up anywhere along the spindle. you said you had to tweak the fittings? that sounds about right. my drivers side brake fitting was bent from the spindle install and it would pull SO hard to the right whenever i hit the brakes.
ocbaud is offline   Reply With Quote
Old 04-16-2004, 01:46 AM   #5
1FaastC10
1FaastC10's Avatar
have you driven the truck yet?
1FaastC10 is offline   Reply With Quote
