Old 09-01-2017, 02:45 PM   #1
Tony71c10
Screws
Where can I get the screws to secure the cowl hood as a set or what size are they. Thanks in advance
Tony71c10 is offline   Reply With Quote
Old 09-01-2017, 03:14 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Screws
Are these what you are looking for?
http://www.classicparts.com/1967-72-...info/38%2D173/
http://www.classicparts.com/1967-72-...info/38%2D159/
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 09-01-2017, 06:47 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Screws
The size of the tap screws is debatable. Personally I believe they're a large #8 or small #10. I would start with #8, which is what I believe the part houses offer anyway. Keep that in mind as you read the following:
The panel mounts onto the cowl using six phillips tap screws with integrated washers. The screw threads are #10" x 5/8". These screws also hold the cowl seal in place.
The panel also mounts to the cowl using four phillips stainless steel tap screws & U-nuts."" The screw threads are #10 x 1/2". The holes for these are nearly parallel of the windshield wiper mounts. The U-nuts are 1/2" x 5/8, and the hole center to edge is 1/2"".
The panel also mounts using four 1/2" recessed hex head tapered screws with integrated washers. One fits behind each door, and one on each corner of the cowl. The threads on three of these screws are 5/16-18 x 7/8. The thread on one screw is 5/16-18 x 3/4. The shortest thread was used behind the RH door, which probably means nothing. 3/4" or 7/8" should work. Also, they don't have to be tapered. They just happened to be on the truck I'm rebuilding.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-01-2017, 07:24 PM   #4
Tony71c10
Re: Screws
Thanks for the info. Best site for our c10s.
Old 09-01-2017, 11:18 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Screws
Here's a reference pic if helpful: http://67-72chevytrucks.com/vboard/s...2&postcount=58
Old 09-02-2017, 12:43 AM   #6
FirstOwner69
FirstOwner69's Avatar
Re: Screws
Another reference. These are originals.
FirstOwner69 is offline   Reply With Quote
