Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-02-2017, 12:52 PM   #1
nxtruck
nxtruck's Avatar
Longbed driveshafts
To the guys that race longbeds,
What are you using for a driveshaft? I'm having vibration issues with a 3 1/2" mild steel shaft at high speeds and high rpms and am trying to convert back to a HD-style 2-piece shaft. I'm curious as to what everyone else is using.
Thanks in advance!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 09-04-2017, 12:01 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Longbed driveshafts
I run a custom 2 piece on mine.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 09-06-2017, 11:57 AM   #3
nxtruck
nxtruck's Avatar
Thanks for the reply!
I had a local shop build a custom 2-piece for mine, also. It's based on a 2-piece shaft from a 68' C-20, which uses the HD-style carrier bearing.
Have you had any trouble out of your carrier bearing?
Chris
Old 09-10-2017, 05:32 PM   #4
71Dragtruck
No problems yet, my truck is 4 - linked so doesn't have the factory crossmember, actually my truck has no factory crossmembers at all just the frame rails are stock.
So anyway not sure that the steady bearing is even from anything in particular or just a heavy duty universal piece, guy that did the 4 - link had it built. So far the only thing I've ever hurt on it was I ripped apart the trans yoke, it split and ripped apart, went to a chrome moly piece after that, the rest has survived fine so far.
Sponsored by:
Hard Candy Customs
Old 09-10-2017, 09:08 PM   #5
nxtruck
nxtruck's Avatar
Cool. Glad to hear that it has held up for you. Hopefully mine will do the same.
Thanks again for the input!
Chris
Old 01-14-2018, 01:29 PM   #6
nebdrummer
nebdrummer's Avatar
pstds carbon fiber 69" long on mine. held a 1.4x 60 ft at 4000 lbs so far. hoping for low 1.3s next year. lifetime replacement warranty, but they aren't cheap.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 01-14-2018, 06:59 PM   #7
l78vetteman
l78vetteman's Avatar
What carbon fiber shaft did you get? Diameter?
l78vetteman is offline   Reply With Quote
Old 01-14-2018, 07:27 PM   #8
nebdrummer
nebdrummer's Avatar
I'm pretty sure it's 3.75" give the guys a call and they will hook you up. Received mine in about a week. Light as it gets.
Old 01-14-2018, 07:27 PM   #9
nebdrummer
nebdrummer's Avatar
http://www.pstds.com
Old 01-14-2018, 10:21 PM   #10
steven03
Anybody run an aluminum single piece driveshaft on a long bed? Almost to the point where i need to get a drive shaft made for my 65 long bed. turbo 5.3 ls and 4l80e will be around 550-600 hp at the wheels. Going to leave off the foot brake no transbrake yet
steven03 is offline   Reply With Quote
Old 01-14-2018, 10:59 PM   #11
nebdrummer
nebdrummer's Avatar
Gotta look at the critical speed for the length, power, and weight. Another reason I went with the carbon fiber was if it breaks, damage will be minimal.
Old 01-18-2018, 09:10 PM   #12
steven03
For those of you running a 2 piece driveshaft which type of carrier bearing are you using? The aluminum and poly type that can be bought through ccp? or the wide oem type?
Old 01-19-2018, 12:32 AM   #13
Captainfab
60-66 Nut
I would never use that POS light duty carrier bearing up top. Those are why so many people dislike 2pc driveshafts. I always use the HD carrier bearing on the bottom.
Old 01-25-2018, 02:00 PM   #14
cruizin01
I'm planning on having one made in the next couple weeks. The shop I'm using recommended a 4" alum shaft for my truck. ~71" length.
cruizin01 is offline   Reply With Quote
Old 01-28-2018, 07:37 PM   #15
NC_John
NC_John's Avatar
What is your gearing? I've got a t-56 with a 4.56 rear. 28" tall rear tires. Dyno'd at 590 hp on 87 octane at the flywheel. Haven't had it on a chassis dyno yet (still reassembling the truck).
The Driveshaft Shop (driveshaftshop.com) told me last week, after they suggested it, that a one-piece aluminum driveshaft 69" long at the predicted max rpm (based on 160 mph) would not hold together. They said a carbon fiber probably wouldn't either and I needed a two piece steel. That was mid last week and I still have not heard back from them.
I might call Denny's Driveshaft this week and see what they would put together. The Driveshaft Shop has a good repuation and they are local but i'm not impressed with them right now.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-29-2018, 08:49 AM   #16
PGSigns
PGSigns's Avatar
John what max rpm did you use? Predicted rpm at 160 at 1 to 1 or the max you plan to turn your engine? My little calculator shows 8770 in 4th gear and a bit over 7000 in 5th for 160
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-29-2018, 12:22 PM   #17
cruizin01
You have a lot more going for you than i do. Mines just a little mild 402. For now I'm just sticking with the stock 3.08 gear and the 4l80e. After I posted this, I shopped around and found a reputable guy that's gonna build me a steel shaft for about half the cost of the aluminum.
Old 01-29-2018, 08:43 PM   #18
NC_John
NC_John's Avatar
Jimmy
They came up with 8755 rpm. Not sure what calculator they used.
I ran an online calculator I found to figure out theoretical top speed and it was over 240 mph. I think I used a max rpm of 6,500 rpm and even with the 4.56 rear, the double overdrive (0.50 6th gear) sets it up for bonneville. I'd probably need 1,200+ hp to get THAT kind of speed out of this big brick so figured 160 mph was reasonable (if I was stupid enough to try to get going that fast).
1970 C-10 LWB "Blu"
Old 01-29-2018, 08:47 PM   #19
NC_John
NC_John's Avatar
I think right now mine is a 403 (6.0 stroker). I've got a stupid amount of money in it but happily, it shows.
1970 C-10 LWB "Blu"
Old 01-30-2018, 08:14 AM   #20
PGSigns
PGSigns's Avatar
I would be looking at pulling gear out to get the drive shaft speed down to 6500 at 160 and that will also help the pinion bearings survive for a long top speed run. It will take a lot of power to get to 160 even with the drag that a truck produces. Then there is the nut factor at speed with the poor aerodynamics and little or no down force.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-30-2018, 10:15 AM   #21
NC_John
NC_John's Avatar
Jimmy
That gear is way too much fun around town to change out. I just need to get realistic about an anticipated top speed. I doubt I'll ever really get higher than 120 for a few seconds on the interstate. Not sure what it might pull in the 1/4 mile.
thanks
1970 C-10 LWB "Blu"
Old 01-30-2018, 08:23 PM   #22
PGSigns
PGSigns's Avatar
There is always a taller tire.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-10-2018, 10:53 PM   #23
Hollow65
Hollow65's Avatar
Jimmy
This, I recently rebuilt the posi and trans and was contemplating a gear swap from 4.11 to 3.42. Tires are cheaper and easier.
I also run a 2 piece with the hd carrier. There isn’t a time I’m driving I don’t abuse my truck. I’ve done 1/8th burnouts, donuts, rolling burnouts on the highway. Nothing wrong with a 2 piece.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 02-11-2018, 07:49 AM   #24
NC_John
NC_John's Avatar
I've got Precision in Tampa building me a 2-pc steel driveshaft. They also recommended i upgrade my pinion yoke (as that would be the next weakest link) so I am doing that as well. Should see everything here this week.
When they asked what my top speed would be I said "you tell me what the limit on the shaft is." In reality, the only time the truck will even see triple digits is in the quarter mile and the occasional freeway on-ramp/short burst (just because). I still have to ask Matt what the critical driveshaft speed will be for my setup but whatever it is I'll just use it as my speed limiter.
I've got 20's all around but should be able to get a slightly taller tire out back when these ones get spent (they're still new).
1970 C-10 LWB "Blu"
Old 02-11-2018, 10:18 AM   #25
cruizin01
Fit the new 4" steel shaft up this week. It was pretty light, almost seemed like aluminum but wasn't. Im happy with it for $250. They were able to use the stock yoke from the 4l80e and the small'ish 1310 rear joint. Should be fine for my setup. I wont know for a little while till I get it on the road though.
