Old 09-07-2017, 08:02 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Windshield wiper problem
I got my 81 Chevy Stepside back from the painter and the windshield wiper arms were not attached. I took them and got new wiper blades then attached them back to their proper places. But the first time that I tried to turn them on they both went down and slammed/stuck against my shroud near the windshield scratching up my new paint job. They stuck there and I had to bend those things to get them to go back. Thinking they may have been put on wrong I put them back on again, this time with a higher angle, but when I turned on the windshield wiper switch again the same thing happened. What in the world would cause this?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 09-07-2017, 08:49 PM   #2
70K10Hunter
70K10Hunter's Avatar
Re: Windshield wiper problem
I have found with windshield wiper arms, when removed or need repair is to always turn wipers on and let cycle a turn or two shut them off and they should return to the park position. With that being said did your painter remove them? if so I would be checking for correct assembly.
70K10Hunter is offline   Reply With Quote
Old 09-07-2017, 09:10 PM   #3
HIGHWAY BY THE SEA
As far as I know he did not remove them because they had paint all over them. I had to scrape it off.
Old 09-07-2017, 09:18 PM   #4
70K10Hunter
confirm they operate correctly, pull arms, turn wipers on, watch to see they are working then shut them off and pay attention where they come to rest.(park position) then reinstall and check.
Old 09-07-2017, 10:56 PM   #5
HIGHWAY BY THE SEA
The last time I tried that it did not seem to work. When I put the wiper arms back on they wanted to go down then up. I will try it without the wiper arms for a while and see what happens.
Old 09-14-2017, 03:31 PM   #6
HIGHWAY BY THE SEA
UPDATE
I put the wipers on the nubs with the wipers straight up. They go down to the bottom of the windshield, then back up again. WTH?!?!?! Installed wrong????
Old 09-14-2017, 05:15 PM   #7
st1
st1's Avatar
is something plugged up backwards?
is the motor in wrong? curious to say the least....
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 09-14-2017, 06:38 PM   #8
70K10Hunter
sounds like it is maybe assembled wrong, IIRC the arm that bolts to the motor is keyed and it might be possible to install arm lever 180 degrees out?. I might have missed this but did the wiper arms work before painting? any other work done on it? did the wipers work previously. What has changed?
Old 09-14-2017, 06:48 PM   #9
70K10Hunter
I just went out and looked at my truck. With the hood up if you look in the oblong hole just above the wiper motor you will see the arm that bolts to the motor. With my wipers at the rest position the arm is pointing horizontal long side towards the driver fender. My truck is a 77 but I would imagine that it is the same on yours.
Old 09-17-2017, 09:46 AM   #10
gmachinz
Im willing to bet your body guy didnt tighten the 2 machine screws which hold the clamp over the ball of the wiper motor arm. It the linkage inside the cowl area doesnt move side to side very much, this is most likely the problem. That would suck though because to access that area requires removing the upper cowl plenum panel. If the linkage DOES fully move side to side, then its likely the splines on the wiper arm attachments are stripped or, the locking tabs are broken on the arms themselves and the arms could be stripped too. I've found most body/paint guys are terrible mechanic and vice versa lol. Im both a mechanic and a paint/body guy so I understand your frustration here.
gmachinz is offline   Reply With Quote
Old 09-17-2017, 05:31 PM   #11
Jstock85
Take them off and re-park them. Once you get them off you'll see what I'm talking about. simply raise them up and press them back in.
Jstock85 is offline   Reply With Quote
