Old 09-08-2017, 10:58 PM   #1
jwaldo880
Frankenstien Help
I'm working on a 68 GMC and have hit a road block with the frame and rear end.
The truck has front disc brakes / rear drums with a 5x5 wheel pattern, leaf springs in the rear. No VIN stamped on the driver side frame rail next to the motor and I am trying to avoid pulling the cab. Any other thoughts on how to identify what I might have frame wise. My next step is to get it up on a lift this weekend and take some pics and measurements.
The rear end has me puzzled even more. 10 bolt, 8.5 rear end but the axle stamp is BN3 G212 2 which according to the GM website would be a 3.08 in a 12 bolt. This obviously doesn't match unless I am reading the code wrong on the tube. Several other numbers on the pumpkin that look like casting numbers.
My brain is fried. Thanks in advance
jwaldo880 is offline   Reply With Quote
Old 09-08-2017, 11:21 PM   #2
Blue GMC
Blue GMC's Avatar
Re: Frankenstien Help
Honestly your frame may not be stamped as GMC i know did not stamp the 67 frames. If it was an early production 68 may not be stamped as well. Not hard to change over to a disc break set up off a donor truck which someone may have done in the past for safety.
Blue GMC is offline   Reply With Quote
Old 09-08-2017, 11:23 PM   #3
jwaldo880
What about the leaf springs, thought they didn't change over to leafs until 70?
Old 09-09-2017, 12:42 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Gmc's seem to be more common with leaves in my expierence but coils or leaves could be had from the factory in any of the 67-72 Chevy/gmc trucks. They were both available all the way thru the production run.
Tyler
Old 09-09-2017, 10:10 AM   #5
jwaldo880
Thanks guys. Any thoughts on the rear end. I had suspected that a donor rear end might have been used but the numbers BN3 G212 telling me it is a 308 12 bolt really confuses me as it is a 10 bolt 8.5
Old 09-09-2017, 11:47 AM   #6
Daves70
Daves70's Avatar
The rear is likely a mid 80's rear end out of a square body truck. The front end parts for the disk brakes could very well be off the same truck. Your frame may be original to the truck.
Daves70 is offline   Reply With Quote
Old 09-09-2017, 10:39 PM   #7
Mike C
Mike C's Avatar
How wide are the leaf springs? 67-72 2x4 trucks should be 2 1/4" wide. If they are 2 1/2" that opens up a whole 'nother can of worms.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-10-2017, 06:31 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
There are some real gurus in here that can tell you what you have in the way of a frame with a few pictures. What does the SPID look like? If you want to post a pic of the SPID, maybe leave the serial number off the top edge, for personal security reasons.
~Steven
Simi Valley, CA
Old 09-10-2017, 10:11 PM   #9
jwaldo880
Mike C the leafs at 2 1/4. Thats a huge help as I was questioning if I might have a car frame.
Old 09-10-2017, 10:14 PM   #10
jwaldo880
Steevedee, unfortunately I am not a guru, just a shade tree tackling a project with my son....so what does SPID stand for?
Old 09-11-2017, 09:16 AM   #11
clay68c10
clay68c10's Avatar
The SPID is the option sheet stuck to the inside of the glovebox door. It lists all the options your truck came with. The SPID isn't always there, or may not be readable.
Mine is long gone after a repaint in 91.
I'd bet someone swapped in square body parts, that's a common and easy way to get rid of the front drum brakes. That swap also changes over to 5 lug from 6. Not a big deal, I'd say it's a bonus.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-11-2017, 09:37 AM   #12
jwaldo880
Thanks Clay, the plate in the glove box is gone. I have found the vin for the cab and numbers off the motor and transmission, the frame and the rear-end are the two that have stumped me. My main concern is ordering parts as I don't know exactly what to get, so I'm guessing a little trial and error at the local auto parts store is in my future. I do like the 5 lug as it seems like I have better wheel options and the disc brakes on the front are a bonus, would be nice if I could convert the rear as well.
