09-09-2017, 05:57 PM | #1 |
Rams horn manifolds
I thought I saw one time a set of Rams horn manifolds that would accept an A/C compressor, but I believe they were for the 67/72 models. Would they work for a 73/80 with an A6 compressor?
Does anybody know where I could acquire a set? if in fact they do. |
09-11-2017, 01:34 PM | #2 |
Re: Rams horn manifolds
I bought a new set of 2 1/2" Chicom Rams Horns at Pate this yr & they both have the bracket on them to mount something, A/C comp or wind mill I don't know...
09-11-2017, 03:13 PM | #3 |
Cruzzzn' Vet
How about these?
http://www.speedwaymotors.com/Corvet...fold,9133.html |
09-11-2017, 04:06 PM | #4 |
The bracket on the 2.5" models is for a mid-1960s generator.
For a pickup you really need the ram's horns with angled outlets to clear the crossmember. However, I don't know if they would clear your compressor, since they rise up much higher than the 73-87 "log type". Dorman 674201, left side (Right side is 674199)
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-11-2017 at 04:25 PM. |
09-11-2017, 08:02 PM | #5 |
thanks guys. Upon further investigation I noticed that my A/C comp has a rear support mount which bolts between the 2nd and 3rd bolt hole and the Rams horn ain't gonna make it. So I guess its the log style or maybe some headers and make spacers for the rear support.
Gotta have my A/C it is Texas you know. |
09-11-2017, 10:12 PM | #6 |
Rottenwood Garage Member
This is a common misconception. Straight dump 2.5 ram horns clear fine. I put them on every 67-72 I built over the past 20 years. 2x4, 4x4. Now with that said, the kick backs do allow for less of a bend at the start of the exhaust pipe and i will certainly give them a try on one of my next builds!.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
09-11-2017, 11:37 PM | #7 | |
On my 82 C10, I might have been able to make them fit had I notched the motor mount clam shells, but would have had the same issue with the tight bends. If the OP needs manifolds, I have these sitting on the shelf. They're for a 96-up 350. I used them on my 82 C10 for a year or so before I switched to headers. What I like about them is they don't have air injection ports. The stub pipes and flanges are 2-1/4".
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-19-2017, 08:17 PM | #8 | |
09-19-2017, 08:50 PM | #9 | |
96-up trucks use a Y pipe with CATs and probably wouldn't fit an 73-87 anyway.
09-21-2017, 09:43 PM | #10 |
GM Addicted
N2trux has a set of 2.5 ram horns on his truck
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage Last edited by 54Caddy; 09-21-2017 at 09:58 PM. |
09-22-2017, 06:05 AM | #11 |
Collector of Projects
I have a factory 2wd 78 Blazer and asked a friend to swap some 2.5" ram horn manifolds from the old headers. I was in the process of moving so it would have been a perfect time. He came back a week later and said they wouldn't fit.... They were Speedway Motors smoothie that dump straight down...
09-22-2017, 09:39 AM | #12 |
54Caddy -- That is a very nice installation, at least on the passenger side. Do you know if he had to notch the driver side clam shell to clear the manifold flange?
And I wonder what the driver's side head pipe bend looks like. On my 82 C10, it would have been a severe bend starting right at the flange to clear the crossmember.
09-24-2017, 05:10 AM | #13 |
GM Addicted
No he says in thread that he didn’t have to notch motor mounts. Passenger side he did change to a mini starter since OEM style was bad so I’m sure that helped with clearance a bit. Drivers side I’m sure has a crazy bend to it but that’s all just in finding an exhaust shop that knows what they’re doing.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
09-25-2017, 02:11 PM | #14 |
anyone have these on their stock height 4x4s?
79 Corvette- 406/7004r Holley EFI 87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4 |
09-27-2017, 12:51 AM | #15 | ||
Happy to be here
Later when we installed the 4 link, I had to cut the system shorter to clear. Now its just loud, and doesnt sound as clean. I plan to make changes to that soon.
09-27-2017, 01:37 AM | #16 |
So I have a 78 factory 2WD with a SBC. I used a late model factory mini starter. I have a serpentine belt setup so I should be OK with the ram horn manifolds?
Would you recommend studs for the manifolds? Have a part number? I would guess Dorman should make some... |
